The Wasp WWS250i is a 2D handheld pocket-size scanner perfect for error-free, on-the-go, wireless scanning. Its durable housing and compact size make the WWS250i the ideal pocket scanner for the mobile workforce. The WWS250i allows you to streamline business processes, maximize efficiency, and eliminate costly data entry errors on nearly any platform.
The pocket-sized form factor makes it ideal for environments where mobility is vital, including retail, office, healthcare, warehouse management and more. Pair the scanner with your mobile device or PC for a quick mobile solution. Built for busy, high-use environments, the WWS250i has an IP55 rating against moisture and dust and its durable housing is able to withstand multiple drops preventing downtime and costly repairs. Haptic feedback, along with the LED and beep tone indicators, inform users of the power status, wireless connectivity, and barcode detection.
- Wasp WWS250i Pocket Barcode Scanner - barcode scanner
- Barcode scanner - portable - Bluetooth 2.1 EDR
- Minimum Bar Width
- 5 mil
- Scan Speed
- 30 frames / sec
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth 2.1 EDR
- Battery
- 1 x Lithium Ion
- System Requirements
- Microsoft Windows, Android, Apple iOS
- 4.25 cm x 10.2 cm x 2.15 cm
- 70 g
- 2-year warranty
Barcode
- Interface Type
- Bluetooth 2.1 EDR
- Minimum Bar Width
- 5 mil
- Frame Rate
- 30 frames / sec
- Print Contrast Signal (PCS)
- 45%
- Decode Capability
- Code 93, Matrix 2 of 5, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, Code 32, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, PDF417, Data Matrix, Codablock F, IATA 2 of 5, UPC-A/EAN-13 with Extended Coupon Code, EAN-UCC Composite, Micro QR code, China Han Xin Code, Codablock A, MSI
- Wireless
- OK Notification
- Beeper, LED indicator
- Bluetooth 2.1 EDR
- Cables Included
- 1 x USB cable - 1.5 m
- FCC Part 15 B, FCC Part 15 C, EN 60950-1, IP55, EN 300 328, IEC 62471, EN 301489-1
- Electric Current Required
- 45 mA (standby), 330 mA (operating)
- Battery
- 1 x Lithium Ion
- OS Required
- 4.25 cm
- 10.2 cm
- 2.15 cm
- 70 g
- Limited warranty - 2 years
- -10 °C
- 40 °C
- 0 - 95% (non-condensing)
- Drop Specification
- 1.5 m to concrete
