ViewSonic VX2209-3 22" 1920x1080 5ms VGA DVI LED Monitor
VIEWSONIC NOW OFFERS ONE EXTRA YEAR WARRANTY!
Quicklinx: B7SGWS00 Mfr#: VX2209-3
The ViewSonic VX2209 is a 22'' Full HD LED display with premium glossy-finish, slim bezel design and stylish glass base, featuring a 1920 x 1080 resolution, 20M: 1 DCR and a 5ms response time to deliver crisp color performance. Equipped with DVI and VGA inputs, it can easily connect to a PC or laptop for office work, internet browsing or home entertainment. With an energy-efficient LED backlight and ECO mode, the VX2209 is an environmentally friendly display choice. Furthermore, the VX2209 provides sRGB and Color Adjust functions, offering image reproduction quality that closely matches the original image source.
  • Slim bezel with premium glass base
    VX2209 adopts a slim bezel and premium glass base design that is available in black. These features increase the screen surface area, giving the VX2209 a sleek, fashionable look that stands out in any setting.
  • Full HD 1080p for superior pixel performance
    The ViewSonic VX2209 features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of playtime, and is perfectly compatible with multi-window viewing without toggling.
  • Planet-friendly mercury-free LED backlighting
    LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy when compared to conventional displays. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space.
  • Eco-mode conserves more energy
    ViewSonic's proprietary Eco-mode feature is built into all LED displays, offering options to select "Optimize" or "Conserve" settings that save power. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the display's lamp life. With Eco-mode, both lamp replacement and energy expenditures are reduced.
  • 20M: 1 MEGA dynamic contrast ratio
    Dynamic contrast ratio detects the brightness of an image, and automatically adjusts the backlight to maximize the monitor's color range and contrast. Dynamic contrast ratio technology enables the accurate reproduction of images, producing vibrant and rich visual effects.
  • Reviving color with sRGB color correction technology
    Accurate and consistent color performance is essential for professionals in graphic design, video editing, and other professional environments. With built-in sRGB color correction technologies, the VX2209 reproduces 100% sRGB rich color performance and captures images in their original and true colors.
ViewSonic VX2209 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
50.11 cm x 21.5 cm x 35.58 cm
3.07 kg
RoHS, WEEE, CU-EAC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio, slim bezel design, Mercury free
50.11 cm x 21.5 cm x 35.58 cm - with stand
3.07 kg
Mechanical
Tilt
Tilt Angle
-3/+20
1 x VGA cable
Backlight Life
30,000 hours
RoHS, WEEE, CU-EAC
Power Supply
External
Input Voltage
Power Consumption (Typical)
24 Watt
Dimensions & Weight Details
Without stand - width: 50.11 cm - depth: 3.357 cm - height: 29.78 cm - weight: 2.46 kg , With stand - width: 50.11 cm - depth: 21.5 cm - height: 35.58 cm - weight: 3.07 kg
10 - 90% (non-condensing)
