The VG2439m series widescreen monitor is one of two members of ViewSonic's VG39 family. Its 24" display with a native 1920 x 1080 resolution is big enough to replace dual monitor setups. What makes it even more appealing is the LED backlight for up to 50% energy savings. Monitor is also fully ergonomic with 90º pivot, height adjust, swivel and tilt. The slim bezel design coupled with hidden stereo speakers make the VG2439m a space saver.
The VG2439m-LED features DisplayPort, DVI-D digital, and a VGA analog input. You can connect multiple sources at the same time and then toggle between them by selecting the input source through the On-Screen-Display (OSD). You can also connect one of your computer's USB ports to the monitor's USB uplink input which then multiplies the USB ports to two. This way, you can connect your keyboard/mouse or other peripherals to your monitor directly and save yourself from the hassle of reaching to your computer's USB ports.
High performance DisplayPort connectivity
The VG2439m-LED is equipped with DisplayPort digital interface, which transmits both audio and video signals through a single connection to deliver ultimate versatility and performance. DisplayPort supports all kinds of multimedia devices for convenience in video production, graphic design and more. -
Efficiency and comfort
Ergonomics is defined as profession of designing tools and work environments to best accommodate human performance and behavior. The VG2439m-LED is one of the great examples of an ergonomically designed tool. Based on your height, chair and desk conditions, you can adjust it up and down for 5.3", swivel it 360°, or tilt it 20°, whatever makes you more comfortable. -
Diverse connectivity
The VG2439m-LED features DisplayPort, DVI-D digital, and a VGA analog input. You can connect multiple sources at the same time and then toggle between them by selecting the input source through the On-Screen-Display (OSD). You can also connect one of your computer's USB ports to the monitor's USB uplink input which then multiplies the USB ports to two. This way, you can connect your keyboard / mouse or other peripherals to your monitor directly and save yourself from the hassle of reaching to your computer's USB ports. -
Mega dynamic contrast ratio
One of the great features of VG2439m-LED is its ability to dim the backlight completely for pure darkness during dark scenes, such as a night shot in a movie. Contrast ratios refer to the ratio of the brightest color to the darkest color. With traditional CCFL backlit displays, contrast ratios are limited to the fluorescent lamp's ability to dim in order to reproduce darkness. However, with the LED backlight, each LED has the ability to completely shut-off allowing for a near infinite ratio of black to white contrast. The end result is true blacks that result in greater overall image quality. -
Full HD 1080p resolution
The VG2439m-LED features a 24" widescreen with 1920 x 1080 resolution that is capable of displaying a native Full HD 1080p image. Today, devices that can display Full HD content output are getting more and more common. However, without a native Full HD display, you will not be able to experience the picture clarity and the details of the 1080p content you view. -
Eco-mode for up to 50% energy savings
ViewSonic's proprietary eco-mode function comes standard with the VG2439m-LED. When you don't need all of the power the VG2439m-LED has to offer, you have the option to reduce the monitor's brightness, save energy, save the planet and prolong the lamp life.
- ViewSonic VG2439m-LED - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.03 cm x 23.96 cm x 43.52 cm
- 5.7 kg
- Localisation
- Americas
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, cUL, CB, DOC, RoHS, WEEE, UL-AR, GOST-R, REACH, UkrSEPRO, ERP, SVHC
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, colour temperature, H-size, aspect control
- sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
- 56.03 cm x 23.96 cm x 43.52 cm - with stand
- 5.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (HDCP) , Audio line-in (mini-jack) , DisplayPort , 2 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B) , Headphones (mini-jack)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Localisation
- Americas
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 56.03 cm - depth: 5.82 cm - height: 33.27 cm - weight: 3.7 kg , With stand - width: 56.03 cm - depth: 23.96 cm - height: 43.52 cm - weight: 5.7 kg
- Shipping Width
- 63.4 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 50.8 cm
- Shipping Weight
- 7.1 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
