ViewSonic Va2718-sh 27" 1920 X 1080 5ms VGA HDMI LED Full HD Monitor
Quicklinx: FXCQWS00 Mfr#: VA2718-SH
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: VGA (HD-15), HDMI
£110.77 ex VAT
£132.92 inc VAT
The ViewSonic VA2718-sh is a 27" Full HD IPS monitor with HDMI and VGA input for business or home usage. With SuperClear IPS technology and Full HD resolution, images are clear and detailed from a wide range of viewing angles. This monitor provides six ViewMode presets that deliver optimized screen performance in different applications. Even if used for gaming, users can move without screen tearing. Eye-Care technology and energy-saving Eco mode help to eliminate eyestrain from extended viewing periods. With VESA-compatible mount support, this monitor is easy to setup in any environment.
  • Flexible connectivity
    HDMI and VGA inputs give you the freedom to connect your monitor to a wide range of devices.
  • 75Hz refresh rate
    With 75Hz refresh rate, this monitor delivers great visual fluidity and flawless graphics no matter how quickly the in-game action unfolds.
  • SuperClear IPS technology for rich colors at wide angles
    With SuperClear IPS technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • Comfortable viewing
    Flicker-Free technology and a Blue Light Filter help to eliminate eye-strain from extended viewing periods.
  • Low energy consumption
    The energy-saving Eco mode takes energy efficiency into consideration while also offering stunning screen performance.
ViewSonic VA2718-sh - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
62 cm x 23.8 cm x 45.5 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
ISO 13406-2, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, SuperClear, Eco-Mode, Flicker Free technology, Adaptive-Sync technology
62 cm x 23.8 cm x 45.5 cm - with stand
5 kg
VGA , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.5 m
Input Voltage
21.4 kWh/1000h
Power Consumption (Typical)
28 Watt
Power Consumption (Max)
30 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 62 cm - depth: 23.8 cm - height: 45.5 cm - weight: 5 kg , Without stand - width: 62 cm - depth: 4.5 cm - height: 36.2 cm - weight: 4.5 kg
Shipping Width
69.5 cm
Shipping Depth
13.6 cm
Shipping Height
47 cm
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Brand: ViewSonic
