The ViewSonic VA2465SH is a widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use at home or the office. With Full HD resolution, high static contrast ratio, and SuperClear VA technology, the VA2465SH delivers stunning brightness and contrast with amazing screen performance from nearly any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with versatile input possibilities including HDMI and VGA, the VA2465SH allows flexible connection to PC systems, laptops and other multimedia devices. A VESA-mountable design offers additional mount flexibility.
Full HD 1080p for superior pixel performance
This monitor features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience amazing clarity and detail whether it is while working, gaming, or enjoying multimedia entertainment. -
SuperClear image enhancement technology with wide viewing angles
SuperClear image enhancement technology delivers the optimal color performance and extends display viewing angles to more that hundred degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay. -
The power of HDMI
HDMI is the advanced, future-proof video standard, guaranteed for true digital picture clarity. The HDMI interface on this monitor allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptops, digital cameras, and many others for the ultimate true HD experience. -
ViewMode settings for digital content
With a few intuitive scenario presets, ViewSonic's unique ViewMode feature offers excellent screen calibration for accurate color rendering and excellent performance. "Game," "Movie," "Web," "Text," and "Mono" presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications. -
ViewSonic Flicker-free viewing for improved eye comfort
ViewSonic flicker-free displays deliver more comfortable viewing. Rather than using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power - nearly eliminating screen flickering at all brightness levels by providing a constant LED light source. -
Blue Light Filter for more comfortable viewing
ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications. -
Improved color depth with high static contrast ratio
An ultra-high static contrast ratio offers a wider range of grayscale to show deeper, richer colors with more visible details in shadows and highlights. With a high ratio, this monitor can display vivid and realistic images for photo editing, watching movies, or any multimedia application. -
Mercury free LED backlighting
LED backlighting not only enhances monitor performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images, but it's also eco-friendly, mercury-free, and uses less energy than conventional monitors. -
Eco-mode conserves more energy and cuts costs
ViewSonic's proprietary Eco-mode energy-saving feature is built into all ViewSonic LED monitors. Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the monitor's lamp life. With Eco-mode, the lifespan of the LED backlighting is also greatly increased.
- ViewSonic VA2465SH - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5.5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.389 cm x 19.314 cm x 40.719 cm
- 4.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- C-Tick, BSMI, WHQL, CB, PSB, RoHS, WEEE, Green Mark, MEPS, REACH, ERP
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- 5.5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- SuperClear, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
- 56.389 cm x 19.314 cm x 40.719 cm - with stand
- 4.1 kg
- VGA , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 40,000 hours
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
