The ViewSonic VA2261 is an eye-care and environmentally friendly 22" widescreen monitor that features flicker-free and blue light technology, eliminating eye strain over extended viewing periods. Equipped with a LED backlight and Eco-mode, it provides energy savings up to 25%. With 1920 x 1080 Full HD resolution, 5 ms response time, DVI and VGA inputs and VESA mountable glossy finish design, the VA2261 is ideal for both home entertainment and office work. It also has ViewMode technology, including preset text, movie, game, mono, and web modes, allowing users to view better color rendering based on different using scenarios.
Full HD 1080p for superior pixel performance
The ViewSonic VA2261 features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of playtime, and is perfectly compatible with multi-window viewing without toggling. -
Planet-friendly mercury-free LED backlighting
LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves up to 25% more energy when compared to conventional displays. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space. -
Eco-mode conserves more energy
ViewSonic's proprietary Eco-mode feature is built into all LED displays. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the display's lamp life. With Eco-mode, both lamp replacement and energy expenditures are reduced. -
ViewSonic flicker-free viewing for improved eye comfort
ViewSonic flicker-free displays deliver on the promise of more comfortable viewing. Rather than using pulse width modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power - nearly eliminating screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer - without eye fatigue. -
Blue light filter for more comfortable viewing
Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a blue light filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications. -
ViewMode settings for digital content
Enjoy excellent performance and accurate color rendering for everything you view on this display. With 5 different scenario presets, ViewSonic displays offer best-in-class calibration techniques to bring you the best digital viewing experience. This includes game, movie, web, text, and mono presets to enhance black levels in games and movies, color luster for online images, and color temperature for reading text. -
VESA-mountable
The ViewSonic VA2261 features a 100 x 100 mm VESA-mountable design that allows you to mount the display on a monitor stand or on a wall, depending on your specific needs. You can easily unscrew the base, and then mount the display on its stand or wall mount.
- ViewSonic VA2261 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24825 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 51.32 cm x 16.4 cm x 38.47 cm
- 3.25 kg
- Environmental Standards
- ENERGY STAR Qualified
- ISO 14001, CCC, FCC Part 15, WEEE, RoHS2, EMAS, CEL level 1, NMB-3 Class B, CAN ICES-3 Class B
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Backlight Technology
- WLED
- Eco-Mode, Flicker Free technology, Dynamic Contrast Ratio, Blue Light Filter technology
- 51.32 cm x 16.4 cm x 38.47 cm - with stand
- 3.25 kg
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 51.32 cm - depth: 4.75 cm - height: 30.47 cm , With stand - width: 51.32 cm - depth: 16.4 cm - height: 38.47 cm - weight: 3.25 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
