The ViewSonic VA2246-LED is a 22" (21.5 viewable) widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution and a 10M:1 dynamic contrast ratio, the VA2246-LED delivers stunning brightness and contrast, while a quick 5 ms response time ensures crisp pictures and smooth playback. The display includes a VGA and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional mount flexibility. With an efficient LED backlight and energy-saving Eco mode, the VA2246-LED is an environmentally friendly display choice. In addition, along with one of the industry's best pixel performance policies provides great value for the stylish, high-performance VA2246-LED display.
Full HD resolution for superior pixel performance
You can experience stunning clarity and detail with high-definition office, graphic design, video production, gaming and multimedia applications on ViewSonic's VA2246-LED monitor. It features Full HD 1920 x 1080p resolution to ensure excellent pixel-by-pixel image performance, while its 10,000,000:1 mega dynamic contrast ratio guarantees accurate image reproduction with rich, vibrant visual effects. -
Mega dynamic contrast ratio for sharp, crisp images
A superior dynamic contrast ratio of 10,000,000:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. Combined with an extremely fast 5 ms response time, every motion is naturally and accurately reproduced without any blurs. -
ENERGY STAR certification
The VA2246-LED is environmentally sound, complete with an energy-saving mercury-free LED backlight and Eco-mode. Its ENERGY STAR certification means you save up to 40% in energy costs when compared to regular 22" monitors. -
Energy-saving eco-mode
ViewSonic's proprietary Eco-mode function gives you the choice to optimize (75%) or conserve (50%) energy, thus reducing display brightness and conserving energy by up to 50%. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility while reducing eye fatigue and prolonging the display's lamp life. -
Windows 8 Certified compliance
Windows 8 Certified, the VA2246-LED provides the most updated Windows 8 experience without any compatibility issues. You can experience the Windows 8 operating system with ViewSonic's VA2246-LED display.
- ViewSonic VA2246-LED - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 50.96 cm x 19.76 cm x 36.61 cm
- 3.48 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- C-Tick, BSMI, CB, CCC, PSB, RoHS, WEEE, REACH, UkrSEPRO, ERP, CEL
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
- 50.96 cm x 19.76 cm x 36.61 cm - with stand
- 3.48 kg
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+18
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 40,000 hours
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Dimensions & Weight Details
- With stand - width: 50.96 cm - depth: 19.76 cm - height: 36.61 cm - weight: 3.48 kg , Without stand - width: 50.96 cm - depth: 4.83 cm - height: 31.66 cm - weight: 3.13 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
