ViewSonic TD2421 24" 1920 x 1080 5ms VGA DVI HDMI LCD Monitor
Quicklinx: CQBMWS00 Mfr#: TD2421
Great for public kiosks, POS displays, and other retail and commercial applications, the ViewSonic TD2421 dual-point optical touch monitor lets users execute two-finger pinches, taps, and swipes for fast and intuitive navigation. With Full HD 1920x1080 resolution, 3000:1 static contrast ratio, and SuperClear MVA technology, the TD2421 delivers stunning brightness and contrast with amazing screen performance at nearly any viewing angle. Flexible connectivity options include HDMI, VGA, DVI, and USB ports, and a VESA-mountable design offers additional convenience for use as a wall-mounted display. Whether in retail or deployed in a high-traffic commercial setting, its scratch-resistant surface stands up to heavy use and safeguards its high quality touch experience.
  • Dual-point optical touch
    Touch screens with dual-point optical touch can recognize two points of simultaneous contact, allowing two-finger gestures such as zoom in/out, rotations, and two-finger taps. Optical touch does not require a conductive object for touch recognition, so it is extremely useful in gloved environments such as hospitals and dental offices, or for use with interactive styluses.
  • SuperClear MVA panel technology
    Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear MVA panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • Full HD 1080p resolution
    This monitor features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether while working, gaming, or enjoying the latest in multimedia entertainment.
  • Versatile connectivity
    HDMI, USB2.0, DVI and VGA inputs give you the freedom to connect your monitor to a variety of devices.
  • Dual integrated stereo speakers
    Designed with dual integrated speakers, this monitor combines incredible screen performance with stereo sound for an immersive multimedia experience.
  • VESA-compatible mount
    Mount the monitor as you see fit using its convenient VESA-compatible mount design.
ViewSonic TD2421 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Class
Class F
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Touch-screen, USB 2.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
200 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100 - 240 V (50/60 Hz)
57.108 cm x 24 cm x 39.22 cm
5.16 kg
Environmental Standards
ENERGY STAR Qualified
CB, DOC, FCC, RoHS, WEEE, REACH, ERP, EAC, SVHC
(Austria, Germany, Switzerland - 3 years)
Display Type
Energy Class
Class F
28 kWh
Diagonal Size
24"
Viewable Size
23.54"
Built-in Devices
USB 2.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
SuperClearMVA, Eco-Mode, scratch-resistant
57.108 cm x 24 cm x 39.22 cm - with stand
5.16 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Optical
VGA (HD-15) , DVI , HDMI , Headphones , Audio line-in , 2 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B)
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x DVI cable - 1.5 m , 1 x audio cable - 1.5 m , 1 x USB cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
19 W
19 kWh/1000h
Power Consumption (Typical)
16.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
ViewSonic Wizard
Microsoft Windows XP / 7 / 8 / 10
Dimensions & Weight Details
Without stand - width: 57.108 cm - depth: 5.771 cm - height: 33.98 cm - weight: 4.32 kg , With stand - width: 57.108 cm - depth: 24 cm - height: 39.22 cm - weight: 5.16 kg
Sustainability Information
ENERGY STAR Certified
Regional Warranty Exceptions
20 - 90% (non-condensing)
