A Finer Projection of Ideas and Fun
Time to upgrade your entertainment set to Full HD. With Extremely refined presentation and innovative functions and connectivity, Pro8400 takes projection to the next level. Presenting Full HD 1080p visual experience in 4,000 lumens and 4500:1 contrast, Pro8400 projects Blue-ray movies, HD videos and images in their true nature. Formal meeting or casual occasions, Pro8400 will take audience's breath away with ultimate visual impact.
Designed to enhance connectivity, the built-in RJ-45 network control and Crestron RoomView software extend the impact of your events at even a global scale. You can project images from four remote computers maximum and display a visual source on multiple Pro8400s. Interacting and projecting, Pro8400 makes sharing more fun than you think.
With advanced Optical Zoom System and 1.5X lens set, you can freely zoom and adjust images without sacrificing the quality. Automatic Keystone Correction answers to inevitable image distortion in various environments. The images are instantly squared in correct proportion, what you see is what you get.
Pro8400 supports a wide range of digital visual inputs, equipped with two HDMI, VGA and USB. Through USB connection, you can also play visual contents in your PC or other USB devices.
With top of the line projection quality and smart connectivity, Pro8400 brings your ideas to life!
Crestron RoomView
World's leading brand of web control system makes interactive projection at a global scale.
Digital Keystone Correction: ±40°,adaptivity in any given environment.
Digital Keystone Correction answers to inevitable image distortion in various environments. The images are instantly squared in correct proportion, what you see is what you get.
Full HD 1080p support
ViewSonic's Pro8400 boasts a Full HD 1080p native resolution for sophisticated and crisp images. This projector enhances your entertainment experience by offering the most lifelike and vibrant images with exceptional details, even in bright environments.
HDMI support
HDMI is a compact audio/video interface for transmitting uncompressed digital data. Transmitting speed up to 10.2 Gbps/sec takes in 1080P Full HD signal and presents perfect and uncompromised image quality. HDCP is also supported.
Network Display
Network Display allows images to be played on multiple projectors within local network or on the Internet. No more boundaries to your ideas and imagination.
RJ45 Network Control
Through RJ45, you can schedule, manage and monitor the projector and its lamp status remotely. The unique integrated clock enables users to perform commands even when the host PC is powered down.
Turn Off and Go,saves time and energy
Designed for long-lasting performance,Off and Go feature efficiently cools down the machine once turned off and moderates the inner temperature when unplugged. You can forget all about the traditional time-consuming turn-off procedure.
USB Display
The Pro8400 carries an USB Display function that provides an alternative way to set up your presentation easily and quickly by connecting your laptop to the Pro8400 through an USB cable.
- ViewSonic Pro8400 - DLP projector
- DLP projector - 1080p
- Built-in Devices
- Stereo speakers
- Networking
- Ethernet
- Brightness
- 4000 lumens
- Contrast Ratio
- 4500:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Bulb type
- 280 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Output
- RGB
- Speakers
- Speaker(s)
- Power
- AC 120/230 V (50/60 Hz)
- 360 Watt
- 33.3 cm x 26.3 cm x 12.2 cm
- 5.36 kg
- Built-in Devices
- Stereo speakers
- Networking
- Ethernet
- Data Link Protocol
- Ethernet
Projector
- Brightness
- 4000 lumens
- Contrast Ratio
- 4500:1
- Image Size
- 76 cm - 7.6 m
- Throw Ratio
- 1.4 - 2.14:1
- Resolution
- 16:9
- Bulb type
- 280 Watt
- Bulb life cycle
- Eco-Mode technology, Closed Caption, ViewMatch
Lens
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Type
- Digital
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
Video Output
- Analogue Video Signal
- RGB
Speakers
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B , 1 x microphone - mini-phone 3.5 mm
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Password protection
- Voltage Required
- 360 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- 33.3 cm
- 26.3 cm
- 12.2 cm
- 5.36 kg
- 10 - 90% (non-condensing)
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 31 dB
