The LED light and lasers combine to create a single light source, resulting in vibrant and rich display color that far exceeds that of a normal mercury light projector. In addition to being environmentally friendly, the mercury-free technology also delivers a longer operation life of 20,000+ hours. Paired with dual HDMI ports and its convenient lamp-free design, the Pro9000 is ideal for home cinema environments and Pro-AV installations.
- ViewSonic Pro9000 - DLP projector - black
- DLP projector - 1080p
- Black
- Microdisplay
- DarkChip 3
- Brightness
- 1600 lumens
- Contrast Ratio
- 100000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 186 Watt
- 32.1 cm x 26 cm x 13.3 cm
- 4.3 kg
- Enclosure Colour
- Black
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 1600 lumens
- Contrast Ratio
- Image Size
- 97 cm - 381 cm
- Projection Distance
- 1.5 m - 5 m
- Throw Ratio
- 1.5 - 1.8:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 100 kHz
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Volume, keystone correction
- OSD Languages
- Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -15 / +15
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- Speakers
- 2 x right / left channel
- 2 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) (with adapter) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x remote control - 3 PIN mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x HDMI cable , 1 x VGA / component video adapter , 1 x serial adapter
- Security Features
- UL, TUV GS, C-Tick, cUL, NOM, CB, CCC, PSB, FCC, FDA, GOST-R, CDRH
- Voltage Required
- 186 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 32.1 cm
- 26 cm
- 13.3 cm
- 4.3 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 28 dB
- Sound Emission (Economic Mode)
- 22 dB
