The ViewSonic PJD8653WS is an interactive and networkable WXGA DLP ultra short throw projector that delivers widescreen presentations from a short distance. With an ultra short throw lens, the PJD8653WS can project an 81" image from only 2 feet away. Built with BrilliantColor technology, this projector produces vibrant colors, while 3000 ANSI lumens and 15000:1 contrast ratio deliver sharp images. Equipped with Crestron LAN controller, the PJD8653WS makes it easy for IT admin to remotely control and manage multiple projectors from their workstations. Certified with AMX Device Discovery, the PJD8653WS easily integrates into any size campus or enterprise. In addition, the PJD8653WS is packed with advanced features including HDMI, two integrated 8-watt speakers, auto keystone correction, and DynamicEco. The PJD8653WS is the perfect widescreen projector for small classrooms and meeting rooms.
- ViewSonic PJD8653WS - DLP projector - ultra short-throw - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 300 Watt
- 35.7 cm x 36.7 cm x 23.1 cm
- 7.3 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 120 cm - 380 cm
- Projection Distance
- 0.52 m - 0.76 m
- Throw Ratio
- 0.35:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Input select, keystone correction
- 6-segment colour wheel, BrilliantColor, Crestron RoomView, AMX Device Discovery, IR Sensor, DynamicEco Mode
Lens
- Focus Type
- Manual
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Stereo
- Output Power / Channel
- 8 Watt
- Speakers
- 2 x right / left channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x audio line-in - RCA x 2 , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), security bar
- UL, TUV, C-Tick, cUL, GS, NOM, CB, CCC, EMC, PSB, FCC, IEC 60825-1, FDA, GOST-R, CDRH, KC, TUV Nord
- Voltage Required
- 300 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 35.7 cm
- 36.7 cm
- 23.1 cm
- 7.3 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 32 dB
