The ViewSonic CDE8451-TL is an 84" 4K Ultra HD interactive display, ideal for educational and corporate meeting applications, as well as for scientific and way-finding applications. With 6-point simultaneous touch technology, this large-format display encourages collaboration and allows two or three users to simultaneously write or draw on the display's surface with their fingers or styli. The large-format LED screen and Ultra HD 3840 x 2160 resolution guarantees the ultimate in colour, clarity, and image detail. Equipped with a tempered glass overlay, anti-glare treatment, and rounded corners, the CDE8451-TL is designed for heavy usage in high-traffic areas. The ViewSonic CDE8451-TL large-format display is the perfect solution where ultra-high resolution imaging and touch interactive performance is needed.
4K Ultra-high definition for the ultimate in image quality
With this 84" 4K Ultra High-definition large-format display -ViewBoard series, the high-definition multimedia contents can be explicitly presented in greater detail. Its 3840 x 2160 pixel screen contains over 8 million pixels, which is 4x higher than Full HD display, all images detail are clear, vivid and larger than life.
Advanced 6-point touch capability for group interaction
With 6-point simultaneous touch technology this large-panel display encourages group interaction. Great for interesting group activities, two or three users can simultaneously write or draw on the display's surface at the same time! Its superior touch report rate provides a smoother user touch experience for both educational and corporate applications.
Protective Rounded-Corner Design
Providing a safer learning environment for active students is also an important consideration. That's why ViewSonic's ViewBoard series utilizes a rounded-corner design to help prevent young students from getting injured within their classroom environment.
Tough Anti-Scratch, Anti-Glare Cover
ViewSonic's ViewBoard series is made even more durable by a layer of 7H-hardness tempered glass coupled with an anti-glare glass. This material combination provides anti-scratch benefits, while improving screen visibility in bright environments.
ViewBoard Software for increased efficiency
We've pre-installed our simple and easy-to-use ViewBoard software on all of our Smart White boards and optional slot-in PCs (large-format display). This software lets you write, highlight, edit, and transform documents and images on-screen in real-time. It also features convenient screen recording and magnifying functions, meeting notification alarms, and allows cloud server access to online resources.
Energy-saving LED backlight
ViewSonic's ViewBoard series features the finest energy-saving LED backlight that has a lifespan of over 30,000 hours, and more than a decade of durability. These advantages tremendously lower power consumption and the cost of ownership, while producing a high ROI, making our products a great long-term investment.
Versatile Input Connectivity
Benefit from the improved device connectivity of our ViewBoard series versatile selection of inputs to easily connect and use all the digital equipment in meeting room or classroom. With HDMI to connect to high-definition content sources, and USB, DVI and VGA ports, you have the freedom to focus on the work that is most important.
RS232 connectivity for easy multiple-device management
RS232 connectivity enables you to connect computers and laptops to your ViewBoard series. It also conveniently lets IT personnel more easily manage, configure devices and upgrade firmwares, saving on time and maintenance costs, while allowing larger organizations the ability of better maintaining and controlling larger numbers of devices from centralized locations.
Large-panel display accessories for improved usability and mobility
Large-panel display accessories for improved usability and mobility Students and teachers can use the provided stylus, or their fingers to simultaneously write on our large-panel display. Location is also a key consideration when installing your Smart Whiteboard. That's why it can be wall mounted for a solid and safe user touch experience. Also, we offer a trolley mount that offers you the flexibility to move your display for a better viewing angle.
Edge Border design improves Windows® 8 touch experience
With the unique edge border design that redefines the relationship between the bezel and panel, in particular operating under Windows 8, there are no more dead angles. This design provides an improved user touch experience, and with an easy pull out charm bar, the presenters can operate all windows®8 functions more efficiently and productively.
