Its 27" display with a native 1920 x 1080 resolution is big enough to replace most dual-monitor setups. What makes it even more appealing is the LED backlight for up to 50% energy savings. Monitor is also fully ergonomic with 90º pivot, height adjust, swivel and tilt. The slim bezel design coupled with hidden stereo speakers make VG2732m-LED a space saver. You can put it on your desk or mount on your wall or on any VESA compliant monitor stand.
Uses 50% less power
Without compromising your viewing quality and has eco-friendly mercury-free WLED backlight. -
Multi-functional base design
VESA compliant wall-mount interface and detachable base for ergonomic flexibility with 90º pivot, 5.3 height, tilt and 356° swivel adjustments. -
USB hub
4-port USB hub provides easy connectivity for USB devices. -
Multimedia enhanced
Stereo speakers provide clear and rich sound. -
Widescreen aspect ratio with 1920 x 1080 resolution
The widescreen aspect ratio allows you to view Full HD content in its native format with no stretching or distortion. -
OptiSync digital/analog inputs expand your connectivity
Multi-mode input technology supports both digital and analog (VGA) signals for ultimate compatibility and configuration flexibility. -
Eco-mode
Environmentally-friendly eco-mode reduces power consumption and extends backlight life. -
Stylish slim-bezel design
An ultra-thin bezel lets you see more without taking up valuable desktop real estate.
- ViewSonic VG2732m-LED - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Stereo speakers, USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.31 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1200:1 / 20000000:1 (dynamic)
- Response Time
- 3.4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.2 cm x 24.1 cm x 34.4 cm
- 6.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- FCC Class B certified, UL, C-Tick, BSMI, cUL, NOM, CB, CCC, PSB, IRAM, RoHS, WEEE, CECP, CEL
- 3-year warranty (Austria, Germany, Switzerland - 3 years)
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.31 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 3.4 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, colour temperature, H-size, aspect control
- OptiSync, Eco-Mode
- Black
- 64.2 cm x 24.1 cm x 34.4 cm - with stand
- 6.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DisplayPort , DVI-D , Audio line-in , USB upstream , 4 x USB downstream
Mechanical
- Tilt Angle
- 25
- Swivel Angle
- 356
- Rotation Angle
- 90
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x audio cable , 1 x USB cable , 1 x VGA cable , 1 x DVI cable
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 55 Watt
- Dimensions & Weight Details
- Without stand - width: 64.2 cm - depth: 6.5 cm - height: 39.1 cm - weight: 5.2 kg , With stand - width: 64.2 cm - depth: 24.1 cm - height: 43.4 cm - weight: 6.6 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 3 years
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
