The smart way to computing
ViewSonic's 22" full-HD resolution Smart Display VSD220, powered by Texas Instruments Dual core 1GHz CPU, brings you optimal multitasking and a whole new way to experience the web using Google's Android 4.0 (Ice Cream Sandwich) operating system. With Google Mobile Service (GMS) certification featuring Google Play store, the VSD220 gives access to thousands of Android apps making it perfect for surfing the web, engaging on social networks and more.
The Micro-HDMI port, along with SRS Premium Sound® delivers breathtaking movies, exciting games, online video, or any high-definition multimedia content, for a lifelike and exhilarating experience. Enjoy vivid and crystal clear image quality from VSD220's Full HD 1080p resolution LED display, expanding the Android experience to an immersive viewing adventure.
A Texas Instruments Dual core 1GHz processor completes the smart display experience
Android 4.0 (Ice Cream Sandwich) , powered by a dual core 1GHz CPU, fluidly move between email, games, eBooks, web-browsing, document editing and many other applications benefitting from the multitasking OS and fast switching.
Two-point optical touch - Intuitive operation for enhanced efficiency
VSD220 embraces the innovative, robust and practical "Optical Touch" technology, offering you superior touch performance with excellent stability and response, perfectly suited to the large HD resolution display.
HDMI, Micro SD slot and 2 USB ports
The VSD220 micro-HDMI connector allows video and digital audio input from a variety of HD devices including Blu-ray®, gaming console and external computers enhancing your large screen high definition experience. The built-in Micro SD slot and 2 USB ports provide easy connectivity with high speed transmission storage devices or peripherals, enhancing expansion flexibility and convenience.
Equipped with Wi-Fi, Bluetooth, Ethernet and 1.3MP camera for video conference
VSD220 embeds a range of connection ports including Wi-Fi 802.11b/g/n, Bluetooth 2.1, and RJ45 Ethernet, providing flexible access options for website browsing, cloud access and data exchange. The connectivity allows video chatting via the built-in 1.3MP front camera, microphone and stereo speakers.
SRS Premium Sound® high-end sound quality entertainment
Stereo speakers powered by a digital amplifier and SRS Premium Sound® give great sound and vision, perfectly suited to streaming movies, catch-up TV or checking out YouTube. The headphone socket allows for private listening where the environment or circumstances necessitate.
- ViewSonic VSD220 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Microphone, 1.3 megapixel camera, 802.11b/g/n network adapter, Fast Ethernet network adapter, microSD card reader, Bluetooth 2.1 adapter
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Input Connectors
- HDMI
- Built-in Ethernet
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 100/240 V (50/60 Hz)
- 51.28 cm x 2.19 cm x 35.3 cm
- 4.8 kg
- EN 301 908, EN 61000-3-3:2008, Directive 1275/2008/EC, Directive 2009/278/EC, EN55022:2010, EN 300 328, EN 55024:2010, EN 300 440-2 V1.4.1, EN 300 440-1 V1.6.1, EN 62209-2:2010, EN 50332-1:2000, EN 50332-2:2003, EN 61000-3-2:2009, EN 60950-1:2011, EN 62311:2008, EN 62209-1:2006, EN 301489-1, EN 301489-17, EN 301 511
- 1-year warranty
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Operating System
- Android 4.0
- Configuration
- Dual core ARM Cortex-A9 1GHz, 1GB DDR2, 8GB EMMC Flash
- Built-in Devices
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- WLED
- SRS Premium Sound
- 51.28 cm x 2.19 cm x 35.3 cm - with stand
- 4.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touchscreen
- Micro HDMI , Micro-USB , Network (RJ-45) , 2 x USB 2.0 (Type A) , Headphones (mini-jack)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x micro-USB to USB cable , 1 x micro-HDMI-HDMI cable
- Input Voltage
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - labour - 1 year
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
