TRENDnet's 4-Port Powerline 500 AV Adapter, model TPL-4052E, uses an electrical outlet to create a 500 Mbps powerline network. Two adapters are needed to start a network. Connect network ready TVs, media players, game consoles, and computers to the four Ethernet ports. No CD installation required--encrypted TRENDnet adapters auto-connect out of the box.
500 Mbps powerline networking
Connect four devices to the Ethernet ports
Pre-encrypted for your security
Power Save mode reduces electrical consumption by 80%
- TRENDnet TPL-4052E - powerline adapter - wall-pluggable
- Powerline adapter - 4-port switch (integrated)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- Sync button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 10.5 cm x 6.5 cm x 7.5 cm
- 159 g
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- Localisation
- United States
- 3-year warranty
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- Encryption Algorithm
- 128-bit AES
- Sync button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, FCC
- Status Indicators
- Power, status
- 4 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV - power BS 1363
- Power Device
- Internal power supply
- Voltage Required
- 4 Watt
- Cables Included
- 1 x network cable - 1.5 m
- Localisation
- United States
- Software Included
- Drivers & Utilities
- OS Required
- 10.5 cm
- 6.5 cm
- 7.5 cm
- 159 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
