TP LINK TL-SG1008PE 8-Port Gigabit Desk/Rack Switch with 8-Port POE
Quicklinx: 8WN7WS00 Mfr#: TL-SG1008PE
The TL-SG1008PE is an 8-Port Gigabit Desktop/Rack mountable Switch with all 8 ports supporting the PoE+ standard. It provides a simple way to expand a wired network by transferring power and data over a single Ethernet Cable. With a total power budget of 124W, up to 30W per port, TL-SG1008PE can power more high-powered devices such as wireless Access Points (APs), IP Cameras or IP Phones. Moreover, with innovative energy-efficient technology, the TL-SG1008PE can save up to 75% of the power consumption, making it an eco-friendly solution for your business network.
How This Product Works
All 8 ports of TL-SG1008PE support Power over Ethernet Plus (PoE+) standard which can automatically detect and supply power to any IEEE 802.3af/at compliant device(s). In this situation, the electrical power is transmitted along with data in a single cable, allowing you to expand your network where there are electrical cables or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones.
Overload Arrangement
TL-SG1008PE has a priority function which helps protect the system when its power is overloaded. If all PoE+ devices' power consumption is greater than or equal to 124W, a priority will be arranged among the 8 PoE+ ports, at which point the system will cut off the power of the lowest-priority port.
Port Priority Function
*Priority (port 1 > port 2 > port 3 > port 4 > port 5 > port 6 > port F > port 8): This function helps protect the system if the power becomes overloaded. For example, if port 1, 2, 4 and 7 are using 30W (maximum power per port is 30W, the system power is 120W in total), and there is an additional device inserted into Port 3 at 25W, the system will cut off the power of Port 7 in response to the power exceeding the 120W limit., This means Port 1, 2 and 4 will use 30W, and Port 3 will use 25W, with no power will be supplied to Port 7 as it has the lowest designated priority among the ports in use.
Easy To Use
TL-SG1008PE is easy to install and use. It requires no configuration or installation. With its Desktop/Rack mountable design, outstanding performance and quality, the TP-LINK TL-SG1008PE 8-Port Gigabit Desktop/Rack mountable Switch with 8-Port PoE is a great choice for expanding your home or office network.
  • Overload arrangement
    TL-SG1008PE has a priority function which helps protect the system when its power is overloaded. If all PoE+ devices' power consumption is greater than or equal to 124 W, a priority will be arranged among the 8 PoE+ ports, at which point the system will cut off the power of the lowest-priority port.
  • Port priority function
    This function helps protect the system if the power becomes overloaded. For example, if port 1, 2, 4 and 7 are using 30 W, and there is an additional device inserted into Port 3 at 25 W, the system will cut off the power of Port 7 in response to the power exceeding the 120 W limit., This means port 1, 2 and 4 will use 30 W, and port 3 will use 25 W, with no power will be supplied to port 7 as it has the lowest designated priority among the ports in use.
  • Easy to use
    TL-SG1008PE is easy to install and use. It requires no configuration or installation. With its desktop/rack mountable design, outstanding performance and quality, the TP-LINK TL-SG1008PE 8-port Gigabit desktop/rack mountable Switch with 8-Port PoE is a great choice for expanding your home or office network.
TP-Link TL-SG1008PE - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
124 W
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
8K entries
Flow control, full duplex capability, power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, PoE+
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
29.4 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
124 W
Performance
Bandwidth: 16 Gbps
8K entries
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45 PoE+ - 30 W
External power adapter
140.1 Watt
FCC
29.4 cm
18 cm
4.4 cm
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
8WN7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
