TP-LINK's TD-W8970 300Mbps Wireless N Gigabit ADSL2+ Modem Router is an incredibly robust all-in-one device allowing users to access high-speed internet connections and share them wirelessly at blazing 300Mbps wireless speeds or by using one of its 4 Gigabit LAN ports. With one multifunction USB port, users can share printers locally and share files & media across the local network or the Internet. What's more, this All-in-one device allows for three different connection types: ADSL, Ethernet WAN or 3G/4G connection through a USB attached dongle, giving users the flexibility to access the Internet whichever method is most convenient.
Full Gigabit Ports - More Power to You
With 300Mbps 802.11n wireless and 4 Gigabit LAN ports, the TD-W8970 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
Multifunctional USB Port
Using the TD-W8970's multi-functional USB 2.0 port, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files. Moreover, users can share their 3G/4G Internet connection by inserting a 3G/4G modem into the router's USB port.
Unterchangeable LAN/WAN Port - Versatile Connectivity
The TD-W8970 supports ADSL, Ethernet WAN connections (EWAN), or 3G/4G connections that allow users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port, or 3G/4G attached dongle using its functional USB port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
Virtually Impregnable
The ability to support up to 10 IPsec VPN tunnels simultaneously gives TD-W8970 users the flexibility to setup a virtual private network, to guarantee network security and take advantage of network access whether at home or away, for work or simply to access files from their local networks.
IP QoS - Efficient Bandwidth Control
IP QoS allows network administrators to allot a specific amount of available bandwidth to each network connected device simply by identifying it by its IP address, ensuring that those devices with critical tasks always have enough bandwidth and preventing any one device from hoarding bandwidth from the rest of the users on the network.
IPv6 Ready
This device supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
More power to you
With 300 Mbps 802.11n wireless and 4 Gigabit LAN ports, the TD-W8970 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming. -
Easy sharing
Using the TD-W8970's one multi-functional USB 2.0 port, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files. -
Interchangeable LAN/WAN port
The TD-W8970 supports ADSL or Ethernet WAN connections (EWAN) that allow users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary. Its EWAN to LAN throughput can achieve up to 900 Mbps+ allowing users to unleash the full potential of their networks. -
All-in-one device
The TD-W8970 does the work of several networking devices packed into one sleek device. With an ADSL2+ modem, NAT router and 300 Mbps wireless access point, this device eliminates the need to purchase multiple devices to access and share a high-speed Internet connections.
- TP-Link TD-W8970 - v3 - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2+
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- IPSec VPN tunnels: 10
- PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS, DDNS
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, TR-069
- Firewall protection, DMZ port, NAT support, IGMP snooping, traffic shaping, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, firmware upgradable, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, file sharing, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), IPSec passthrough, FTP server, IPv4 support, port triggering, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DNS relay, static routing
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 22.5 cm x 14 cm x 3.25 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows Vista / XP / 7, Microsoft Windows 2000 / NT, Windows 8.1
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Capacity
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- DES, Triple DES, MD5, 128-bit WEP, 64-bit WEP, IKE, SSL, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Communications
- DSL modem
- ADSL, ADSL2+
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Phone line: 1 x ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A , Antenna: 2 x R-SMA
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Included Accessories
- ADSL splitter
- Cables Included
- 2 x phone cable , 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 22.5 cm
- 14 cm
- 3.25 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
