With the higher resolution, Tapo C510W enhances your security by capturing more details compared with traditional 1080p. The full-color night vision reveals full-color images with built-in spotlights even at night. It provides 360° horizontal and 130° vertical view range to capture everything around.
Tapo C510W tracks motion with high-speed rotation, ensuring you to keep an eye on more vital areas. Smart AI identifies a person, notifying you as needed. You can also set up customizable activity zones or boundaries to only receive alerts that matter.
Record your own audio as an alarm and adjust the brightness for your customized use. Tapo C510W offers excellent waterproof and dustproof performance for outdoor scenarios.
360° visual coverage
It provides 360° horizontal and 130° vertical view range to capture everything around. -
Full-color mode
Two built-in spotlights enable Tapo C510W to capture full-color images for enhanced security. -
Infrared mode
Provides a visual distance of up to 98ft at night while also helping you save more energy with spotlights off. -
Smart mode
Lights up the environment and automatically switches to full-color mode to provide more details when a person or motion is detected. -
2K resolution, see every detail
With the higher resolution, Tapo C510W enhances your security by capturing more details compared with traditional 1080p. -
Smart motion tracking
Tapo C510W tracks motion with high-speed rotation, ensuring you to keep an eye on more vital areas. -
Multiple detection
Customize your detection and keep an eye on what matters. -
Customizable sound and light alarm
Record your own audio as an alarm to extend your usages. The ultra-bright and adjustable light is also supported to frighten unwanted visitors away. -
Secure local and cloud storage
Save recorded videos to a microSD card or by using Tapo Care cloud services. -
IP65 water and dust resistant
Offers excellent waterproof and dustproof performance for outdoor scenarios. -
Two-way audio
Communicate directly with the outdoors for your convenience. -
Physical privacy mode
Maintains your privacy with the lens physically blocked by the housing. -
Voice activated
Enjoy your smart life and keep an eye on your vital areas with Alexa and Google Assistant supported.
- Tapo C510W V1 - network surveillance camera
- Network surveillance camera - pan / tilt - outdoor - dustproof / weatherproof
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- Camera Mount Type
- Wall mount, ceiling mount, pole mount
- 12.38 cm x 12.3 cm x 9 cm
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2304 x 1296
- Frame Rate (max)
- 15 frames per second
- Motion Detection
- Video Modes
- 2K
- Optical Sensor Type
- CMOS - 1/2.8" - 3 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 3.9 mm
- Lens Iris
- F/2.0
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 130
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Voltage
- AC 100-240 V
- Alarm function, Privacy mode, LED indicator, reset button, Colour Night Vision, Person Detection, Smart Activity Zones, Smart AI Detection, Snapshot notification, clips notification
- Environmental Parameters (operating)
- -30 °C - 60 °C; 10 - 90% RH (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Wireless
- 12.38 cm
- 12.3 cm
- 9 cm
Camera
- Colour - Day&Night - pan / tilt - outdoor - dustproof / weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 2304 x 1296
- Motion Detection
- Video Modes
- 2K
- Infrared LEDs
- Infrared Distance
- 30 m
- Digital Video Capture Resolution
- 2304 x 1296
- Frame Rate (max)
Image Sensor
- 3 MP CMOS 1/2.8"
Lens Construction
- Fixed focal
- Focal Length
- 3.9 mm
- Lens Iris
- F/2.0
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 130
- Network Interface
- Network Protocols
- DNS, TCP/IP, UDP/IP, ICMP, HTTPS, TLS, SSL
- Supported Memory Cards
- microSD Card
- Included Accessories
- Mounting bracket, screws, mounting template, anchors, waterproof seal
- FCC, RoHS, AES-128, IP65, RCM, WPA2-PSK, WPA
- Power Device
- Power adapter - external AC 100-240 V (50/60 Hz)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- Tapo app
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Voice Controlled
- Indirect
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 10 - 90% RH (non-condensing)
