TP-LINK's TL-MR3040 is a truly mobile wireless networking platform that when paired with a 3G USB modem, is able to broadcast a wireless signal at up to 150Mbps around a room, creating a mobile office or entertainment network for up to five devices to access the Internet simultaneously. The device is the ideal travel companion, with pocket-sized dimensions and powered by its own powerful internal 2000mAh battery, users can work or play for hours on end. The device is also incredibly easy to use, allowing users to rapidly set up an Internet connected wireless network in as little time as it takes to plug in their 3G USB router or WAN cable and when finished, simply place the device back in their pockets.
Battery Powered - Made to Move
The TL-MR3040 is powered by a 2000mAh internal battery capable of powering a shared 3G network at 150Mbps for up to 4 hours at full 802.11n speed and range. The device can be powered via its USB cable and included adapter by connecting it to a Laptop or PC's USB port. With its powerful internal battery and compact design, the TL-MR3040 is designed to be placed in your nearest pocket and taken on the road. The portable 3G router's elegant exterior improves any desktop, dashboard or tray table on which it rests with slender curves and glossy piano white coating.
Versatile Connectivity
Featuring both a WAN and 3G USB port, the TL-MR3040 is able to utilize both wired and 3G wireless connections to create a powerful wireless network, for use at a hotel, home and on the road.
150Mbps - More Power to You
At 150Mbps, the TL-MR3040 has the wireless speed and range to accommodate several bandwidth intensive tasks at once with coverage for an entire average sized room. With connected 3G USB adapter or WAN cable, users can enjoy online games, stream media, or participate in a conference call, from the convenience of home, their cars or even on the train.
Compatible with HSPA/UMTS/EVDO 3G USB modems Features a 2000mAh battery for maximum usage time Four operation modes available for different situations: 3G Router, Travel Router (AP), WISP Client Router, Wireless Router 150Mbps wireless speeds for rapid sharing and increased signal range
Battery powered - made to move
The TL-MR3040 is powered by a 2000 mAh internal battery capable of powering a shared 3G network at 150 Mbps for up to long hour at full 802.11n speed and range. The device can be powered via its USB cable and included adapter by connecting it to a laptop or PC's USB port. With its powerful internal battery and compact design, the TL-MR3040 is designed to be placed in your nearest pocket and taken on the road. The portable 3G router's elegant exterior improves any desktop, dashboard or tray table on which it rests with slender curves and glossy piano white coating. -
Versatile connectivity
Featuring both a WAN and 3G USB port, the TL-MR3040 is able to utilize both wired and 3G wireless connections to create a powerful wireless network, for use at a hotel, home and on the road. -
150 Mbps - more power to you
At 150 Mbps, the TL-MR3040 has the wireless speed and range to accommodate several bandwidth intensive tasks at once with coverage for an entire average sized room. With connected 3G USB adapter or WAN cable, users can enjoy online games, stream media, or participate in a conference call, from the convenience of home, their cars or even on the train.
- TP-Link TL-MR3040 - wireless router - Wi-Fi - desktop
- Wireless router
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- TCP/IP, PPTP, L2TP, ICMP/IP, PPPoE, CSMA/CA, CSMA/CD
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- Firewall protection, DMZ port, NAT support, VPN support, auto-negotiation, DoS attack prevention, ALG support, firmware upgradable, ACL support, virtual server support, DHCP server, built-in rechargeable Li-ion battery
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 6.2 cm x 10 cm x 1.6 cm
- 94 g
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7
- Wireless router
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
- Status Indicators
- Power, status
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Gain Level
- 0 dBi
- Power Device
- External power adapter
- Cables Included
- 1 x USB cable , 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 6.2 cm
- 10 cm
- 1.6 cm
- 94 g
- 15 °C
- 40 °C
- 0 - 75% (non-condensing)
