TP LINK Pan/Tilt Surveillance Camera 54Mbps Wireless
Quicklinx: 8G9ZWS00 Mfr#: TL-SC4171G
The TL-SC4171G is dedicated to providing 24-hour security monitoring of a home, office, store or any other location needing day and night security. By easily mounting this camera on a ceiling or wall, it offers wide-range pan/tilt monitoring of the entire space in which it is located. Moreover, live video can be accessed through the Internet on a PC/laptop, or even via 3G mobile devices such as Blackberries or iPhones! Featuring a 54Mbps wireless connection, 2-way audio and other practical functions, the TL-SC4171G is a fantastic solution that allows users to keep an eye on whatever they value most.
TP-Link TL-SC4171G - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: two-way audio capability, built-in microphone
11.2 cm 11.4 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/4" - 0.3 MP (640 x 480)
Minimum Illumination
0 lux - IR
Focus Adjustment
(min distance 4.3 mm)
Lens Iris
F/2.0
Panning Range (degree)
354
Tilting Range (degree)
125
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
1 - network cable - external
Voltage
DC 12 V
Motion sensor, IR filter, digital image rotation, saturation control, brightness control, contrast control, e-mail alerts, image flip, image mirror
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
11.2 cm
11.4 cm
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MPEG-4, MJPEG, 3GPP
Max Digital Video Resolution
640 x 480
Digital Zoom
10
0 lux - IR
Infrared LEDs
12
Frame Rate (max)
Still Image Capture Resolution
640 x 480, 320 x 240, 160 x 120
Image Sensor
0.3 MP (640 x 480) CMOS 1/4"
Lens Construction
Lens Iris
F/2.0
Min Focus Distance
4.3 mm
Panning
Range (degree)
354
Speed (degree/sec)
Up to 60
Tilting
Range (degree)
125
Speed (degree/sec)
Up to 80
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, Bonjour, PPPoE, SSL
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Interfaces Details
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-out - mini-phone 3.5 mm , 1 x peripheral - input / output - terminal block , 1 x audio - line-in/microphone - mini-phone 3.5 mm
1 x network cable - external
FCC, RoHS
Power Requirements
DC 12 V
Power adapter - external
Software Included
Drivers & Utilities
Apple MacOS, Linux, Microsoft Windows 7, Microsoft Windows 98/ME/2000/XP/Vista, Microsoft Windows 2003
Additional Requirements
64MB video memory
System Requirements Details
Pentium 4 - 1.8 GHz - RAM 512 MB
Relative Humidity (operating)
