TP LINK JetStream 24-Port Gigabit L2 Managed PoE+ Switch With 4 SFP
Quicklinx: G6X7WS00 Mfr#: TL-SG3428MP
Type: Gigabit Ethernet
Ports: 28
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
£376.40 ex VAT
£451.68 inc VAT
Convenient Gigabit Switch with 24-Port PoE+ for a Complete Omada Network.
  • Dedicated 24 PoE+ Ports (384 W Budget) for numerous applications
    Features 24× 802.3af/at compliant PoE+ ports, the switch supports up to 384 W total PoE power budget. Designed to use a single Ethernet cable for both data and power transmission, it offers flexible deployment for PoE-supported devices such as wireless access points, IP cameras, and IP phones, lowering infrastructure costs for small businesses.
  • Software Defined Networking (SDN) with cloud access
    Omada's Software-Defined Networking (SDN) platform integrates network devices, including access points, switches, and gateways, providing 100% centralized cloud management. Omada creates a highly scalable network - all controlled from a single interface. Seamless wireless and wired connections are provided, ideal for use in hospitality, education, retail, offices, and more.
  • Secure networking
    Security features include IP-MAC-Port-VID Binding, Port Security, Storm Control, and DHCP Snooping to defend against a range of network threats. An integrated list of common Dos attacks is available, making it easier than ever to prevent them. In addition, the Access Control Lists (ACL, L2 to L4) feature restricts access to sensitive network resources by denying packets based on source and destination MAC address, IP address, TCP/UDP ports, or VLAN ID. Users' network access can be controlled via 802.1X authentication, which works with a RADIUS/Tacacs+ server to grant access only when valid user credentials are provided.
  • Advanced QoS
    Voice and video traffic can be prioritized based on IP address, MAC address, TCP port number, UDP port number, and more. With QoS (Quality of Service), voice and video services remain smooth, even when bandwidth is in short supply.
  • Abundant L2 and L2+ features
    A complete lineup of L2 features are supported including 802.1Q VLAN, Port Mirroring, STP/RSTP/MSTP, Link Aggregation Control Protocol, and 802.3x Flow Control. Advanced IGMP Snooping ensures the switch intelligently forwards multicast streams to only the appropriate subscribers, cutting out unnecessary traffic, while IGMP throttling & filtering restrict each subscriber on a port level to prevent unauthorized multicast access. Static Routing is a simple way of segmenting the network and internally routs traffic through the switch for improved efficiency.
  • ISP features
    sFlow, QinQ, L2PT PPPoE ID Insertion, and IGMP authentication features are provided, developed with service providers in mind. 802.3ah OAM and Device Link Detection Protocol (DLDP) offer easy monitoring and troubleshooting of Ethernet links.
  • IPv6 support
    IPv6 functions such as Dual IPv4/IPv6 Stack, MLD Snooping, IPv6 ACL, DHCPv6 Snooping, IPv6 Interface, Path Maximum Transmission Unit (PMTU) Discovery and IPv6 Neighbor Discover guarantee your network is ready for the Next Generation Network (NGN) without upgrading your hardware.
  • Enterprise level management features
    Easy to manage via an intuitive web-based Graphical User Interface (GUI) or an industry-standard Command Line Interface (CLI). For both management methods, traffic is protected through SSL or SSH encryption. SNMP (v1/v2c/v3) and RMON support enables the switch to be polled for valuable status information and to send traps on abnormal events.
TP-Link JetStream TL-SG3428MP - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
384 W
Performance
Switching capacity: 56 Gbps , Packet forwarding rate: 41.66 Mpps
Priority queues: 8 , VLAN groups: 4000
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, OAM, ICMP, DHCP, RSTP, TACACS+, RADIUS
Flow control, VPN support, BOOTP support, ARP support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, DLDP support, LLDP support, DHCP relay, LACP, Port Security, MVR, NDP, port isolation, CoS, SP, GVRP, 802.1x authentication, cloud managed, DSCP support, 2 fans, IP source guard, ARP inspection, BPDU, dual image support, SDN, AAA, LLDP-MED, VLAN group, guest access, ZTP, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, Advanced QoS, MAB, security slot (Kensington security lock compatible)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3at
44 cm x 33 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
384 W
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, TLS 1.2
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Status
24 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x 1000Base-X SFP , 1 x console RJ-45 , 1 x micro-USB console
Internal power supply
463.8 Watt
Rubber feet
Rack Mounting Kit
Included
FCC, RoHS
44 cm
33 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 28
Managed: Yes
POE: PoE+
Brand: TP LINK
