TP LINK EAP115 Radio Access Point GigE 802.11b/g/n - 2.4 GHz
Quicklinx: CMB2WS00 Mfr#: EAP115
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, Gigabit Ethernet, IEEE 802.11g, Fast Ethernet + 2 more
Compatibility: PC
  • IEEE 802.11n
Hurry, only 1 left in stock!
£31.25 ex VAT
£37.50 inc VAT
Express delivery Order within the next 18 hours for delivery on Wednesday
Build and manage a scalable Wi-Fi network for your business with this business-class solution, tailored to handle the power of multiple EAPs at an affordable cost.
  • Easy-to-use cluster mode
    The user-friendly cluster mode allows you to manage EAPs in your business network without requiring any extra hardware or software. Organize your network administration system by controlling multiple access points at a time with the same simplicity of a single home network router.
  • Custom guest authentication
    The captive portal provides customizable guest authentication settings for maximized user control. Administrators can easily set and adjust guest Wi-Fi settings by designing a unique authentication page, establishing a voucher system to limit the duration of use for each client, or creating "Operator" accounts, for permission to manage the guest network without having access to other EAP administrative features.
  • Timesaving and flexible deployment
    The EAP115 is designed for easy installation on any wall or ceiling. The Power over Ethernet (PoE) function allows your network cables to carry electrical power, so you minimize on cable clutter. It's one more hardwiring hassle you don't have to worry about, when operating your centralized management system.
  • Unified Wi-Fi for multi-user environment
    The business Wi-Fi solution is engineered to handle heavy multi-user usage in large areas without encountering the stability issues. It's the perfect fit for motels, salons, chain-stores, schools, and restaurants.
TP-Link Omada EAP115 - radio access point - Wi-Fi
Radio access point
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Microsoft Windows XP, Microsoft Windows Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE
18 cm x 18 cm x 4.75 cm
Radio access point
18 cm
18 cm
4.75 cm
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz
Status Indicators
System
Syslog support, manageable, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, ceiling mountable, security lock slot (cable lock sold separately), Watch Dog Timer (WDT)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
Gain Level
3 dBi
1 x 1000Base-T (PoE) - RJ-45 , 1 x management (RS-232) - RJ-45
FCC, RoHS
PoE
External power adapter
5 Watt
Software Included
Drivers & Utilities
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11g
Protocol: Fast Ethernet
Protocol: IEEE 802.11n
Protocol: Ethernet
Compatibility: PC
Antennas: 2
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
