TP LINK Deco X95 AX7800 2-pack
Quicklinx: H3X9WS00 Mfr#: Deco X95(2-pack)
Type: Wi-Fi system
Connectivity: Wireless, Wired
Speed: 7800Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 4 more
Antennas: 6
  • IEEE 802.11n
Hurry, only 1 left in stock!
£374.99 ex VAT
£449.98 inc VAT
Express delivery Order within the next 22 hours for delivery on Wednesday
Unlock Seamless Coverage By Smart Antennas, WiFi That is Adaptive to Your Unique Home
True Tri-Band Speed
All three WiFi bands work together to unleash your network’s total speeds up to 7,800 Mbps for up to 200 devices
8 Streams, Less Lag
4×4/HE160 4804 Mbps + 2×2/HE160 2402 Mbps + 2×2 574 Mbps
Whole Home WiFi 6
Cover up to 6,100 ft2 with next-gen seamless WiFi and make dead zones and buffering a thing of the past
Up to 2.5 Gbps Wired Connections
1× 2.5 Gbps port + 2× Gigabit port offer high-speed data transmissions.
Seamless AI-Driven Mesh
Unites your home under one name and password while delivering the best connections as you move room to room
TP-Link HomeShield
Keeps your home network safe with cutting-edge features for network and IoT protection
Setup Made Easier Than Ever
The Deco app walks you through setup step-by-step
  • Unlock seamless coverage by smart antennas
    By using intelligent algorithms, Smart antennas auto-detect Deco units and adjust to the most optimal antenna pattern arrays. This way, with 2 smart antennas, Deco X95 creates the ideal network throughout your home.
  • Powerful and exquisite
    Combining Tri-band Wi-Fi with high-tech Wi-Fi 6, Deco X95 provides 8 simultaneous data streams to open up more bandwidth and help your devices operate at full speed. With 2 smart antennas and 4 high-gain antennas, it not only delivers boosted Wi-Fi signals to every corner of your home but also brings a sense of aesthetics.
  • Ultra-fast Multi-Gig Internet connection with 2.5Gbps port
    A 2.5 Gbps port and 2 Gigabit ports make full use of the Gigabit speeds from your local ISP. Breakthrough the 1G bottleneck and drive your devices to peak performance. Plug your PCs, smart TVs, or game consoles into the ports for blazing-fast wired connections.
  • Coverage in all the right places
    To blanket your entire home with Wi-Fi, Deco X95 units work together as a powerful mesh network to boost broader coverage for connections in every corner. It provides an extra 5 GHz band working exclusively as the strong backhaul between deco units.
  • Deco fits any type of your house
    Brick and cement. Floors and ceilings. Walls and hallways. All of them make it tough for Wi-Fi to travel across your home. Deco units work together to move Wi-Fi around the obstacles in your home and deliver complete coverage.
  • Engineered for more devices
    Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance.
  • Intelligent networking for a smarter home
    Deco uses its custom algorithms to automate the connections on your network, ensuring the strongest possible signals at all times.
  • Protect your network and everything on it
    TP-Link's premium security services keep your home network safe with advanced features for network and IoT protection.
TP-Link Deco X95 V1 - Wi-Fi system - Wi-Fi 6 - Wi-Fi 6 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
Wi-Fi System Coverage
Up to 6,100 sq.ft
Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Data Transfer Rate
7800 Mbps
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps , Maximum data rate (5 GHz): 4804 Mbps , Channel bandwidth: 160 MHz
Connected devices: up to 200 , Streams: 8
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6
Routing Protocol
IGMP, static IP routing
Intelligent Assistant
Alexa
Remote Management Protocol
DHCP
Auto-sensing per device, IGMP snooping, Intrusion Prevention System (IPS), parental control, Access Point operational mode, DDos attack prevention, Quality of Service (QoS), DHCP server, port forwarding, Network Access Protection (NAP), reset button, Stateful Packet Inspection Firewall (SPIF), dynamic IP mode, Firmware Over-the-Air (FOTA), tagged VLAN, IGMP proxy, beamforming technology, Tri-Band, router mode, Backhaul Technology, 4x4 MU-MIMO technology, smart aerial, IPTV support, BSS Coloring, Guest Network, TP-Link HomeShield, Address Reservation, Real-Time IoT Protection, Malicious Site Blocker, Home Network Scanner, network access control, AI-Driven Mesh
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, UPnP, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Wi-Fi CERTIFIED 6
AC 100-240 V (50/60 Hz) 0.8 A
13 cm x 12.3 cm x 21.05 cm
3-year warranty
Wi-Fi system - mesh - 3-port switch (integrated)
2 routers
Up to 6,100 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
7800 Mbps
Performance
Routing Protocol
DHCP
Encryption Algorithm
WPA3-Personal, WPA2-Personal, WPA-Personal
Wi-Fi Rating
AX7800
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, UPnP, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Wi-Fi CERTIFIED 6, IC, FCC, RoHS
1.7 GHz
Status Indicators
Status
Line Properties
Line Coding Format
1024 QAM, OFDMA
Internet of Things (IoT)
Alexa
WAN / LAN: 1 x 2.5GBase-T - RJ-45 , WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
Installed Qty
2
Electric Current Required
0.8 A
27 Watt
1 x network cable
13 cm
12.3 cm
21.05 cm
Limited warranty - 3 years
10 - 90% RH
Type: Wi-Fi system
Connectivity: Wired
Speed: 7800Mbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ax (Wi-Fi 6)
Protocol: 2.5 Gigabit Ethernet
Antennas: 6
Brand: TP LINK
