TP LINK 48-port Gigabit Switch
Quicklinx: 77S9WS00 Mfr#: TL-SG1048
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: No
POE: No
29 In Stock
£158.33 ex VAT
£189.99 inc VAT
The TL-SG1048 is specially designed for Ethernet (10Mbps), Fast Ethernet (100Mbps) and Gigabit Ethernet (1000Mbps) with seamless link. Each port supports up to 2000Mbps throughput in full duplex mode. It is the perfect choice to improve the performance of offices and workgroup networks.
TP-Link TL-SG1048 - switch - 48 ports - rack-mountable
Switch - 48 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
44 cm x 36 cm x 4.4 cm
Switch - 48 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
8K entries
Status Indicators
Power, link/activity
48 x 1000Base-T RJ-45
FCC
44 cm
36 cm
4.4 cm
Limited warranty - lifetime
10 - 90%
77S9 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
Ports: 48
Managed: No
POE: No
Brand: TP LINK
