With a combination of performance and reliability, the 38.1cm (15") Satellite Pro R50-C notebook is ideal for any professional environment. Not only can you feel confident in the fast processing speeds of the device's Intel® Core™ architecture, but you can also feel reassured by a solid design that's built to withstand the pressures of daily use. Add to that a heavy typer keyboard and a 3D sensor for data protection and you have a device that's built to last. And with the latest integrated Intel® Premium Wi-FI and LAN, the Satellite Pro R50-C won't date quickly either - making it more cost effective in the long run. The benefits don't end there: the Satellite Pro R50-C has an advanced system that supports silent working, a matt LCD screen for sharp visuals and a full size keyboard - making it both user- and office-friendly. Meanwhile, a Kensington lock offers security for the device itself, and pre-installed McAfee software provides protection for all your data on the inside. You can even take control of your power consumption using the pre-installed Toshiba Eco Utility. As the starting point in a wide range of Toshiba business devices, the Satellite Pro R50-C is the affordable way to meet all your professional needs.
5th Generation Intel® Core™ i3-5005U Processor (2.00 GHz, 3rd level cache: 3MB)
Windows 8.1 64-bit (pre-installed) free upgrade to Windows 10
39.6cm (15.6") Toshiba HD non-reflective High Brightness display with LED backlighting and 16 : 9 aspect ratio, internal resolution: 1,366 x 768
500 GB (5400 rpm ) SATA HDD
4GB System memory DDR3L RAM (1,600 MHz)
Slim DVD Super Multi (Double Layer) drive
Intel® HD Graphics 5500
1 year European Carry-in warranty
Built for Business
Give your business an edge with an enterprise-class laptop built for small- or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R50 will help meet all your computing needs without putting a big dent in your bottom line. -
Power & strength
Powered by the Intel Broadwell 5th generation processor you will be able to more effectively manage your workload wherever the day takes you. Plus, enjoy added security knowing that your Satellite Pro R50 is extra strong thanks to its rigorously tested durable design. -
Equipped for success
Imagine how much more pleasant those spreadsheets will be on a brilliant 15.6" diagonal HD display. The updated keyboard features a US layout with bilingual keys providing the style and experience most professionals prefer. Plus, there is a host of other components mobile employees need to be effective - like plenty of RAM, a built in DVD drive, business ports and much more. -
Security & peace of mind
Toshiba EasyGuard technology helps keep the Satellite Pro R50 secure, protected, connected and optimized. A full suite of safeguard features helps keep your laptop shielded, constantly mobile and your data secure, giving you the time and peace of mind to focus on running your business.
- Dynabook Toshiba Satellite Pro R50-C-107 - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Graphite black, black (keyboard)
- 37.9 cm x 25.8 cm x 2.395 cm
- 2.1 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Hyper-Threading Technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Palm Rejection Technology, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- 2 x USB 2.0 , 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription)
- Case Material
- Polycarbonate ABS
- Security lock slot (cable lock sold separately), administrator password, system password
- Included Accessories
- Power adapter
- Localization
- 2.1 kg
Sustainability Information
- ENERGY STAR Certified
