Toshiba Satellite Pro R50-B-12V - 15.6" Core i5-4210U 4GB 500GB Windows 8.1 64-bit
Quicklinx: 9QTMWS00 Mfr#: 9RPFWS00
  • Core i5
  • Windows 8.1 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
There's a lot more to the Satellite Pro R50-B than a slim, stylish and durable chassis. Open up the lid to reveal the tiled keyboard with numeric keypad, and you're all set to be more productive - without the need to plug in an external keypad. The full-size port layout includes RGB and HDMI too, so you won't have to carry adapters to connect to an external display. Plus, there's a 39.6 cm (15.6") non-reflective HD screen, so you're always free to focus on your business-critical content in clear high definition. With no glare to worry about, you can type emails or create documents in the office, outdoors or wherever's convenient.
  • Windows 8.1 64-bit (pre-installed) Recommended upgrade to Windows 8.1 Pro
  • 4th generation Intel® Core™ i5-4210U processor with Intel® Turbo Boost Technology 2.0
  • 39.6cm (15.6") , Toshiba HD non-reflective High Brightness display with 16 : 9 aspect ratio and LED backlighting
  • Hard disk 500 GB
  • 4,096 (1x) MB, DDR3L RAM (1,600 MHz)
  • Intel® HD Graphics 4400
  • maximum life : up to 6h25min (Mobile Mark™ 2012)
  • weight : 2.3 kg
  • W x D x H : 379 x 258 x 23.95 mm
  • Long-lasting battery
    Busy execs can enjoy unplugged freedom to stay productive for long hours with the removable battery. Plus, Toshiba's battery lifecycle eco-charging mode increases charging cycles by up to 40%.
  • Keeps you productive
    With its rigid and robust chassis, the Satellite Pro R50 has a proven low failure rate. It stands up to the rigors of daily business use, reducing IT maintenance and significantly lowering downtime.
  • Built for business
    The Satellite Pro R50 is designed, engineered, manufactured and tested by Toshiba to help you succeed in business. Enjoy the peace of mind that this reliable professional notebook keeps your business moving forwards.
  • Smart, thin and light
    The stylish, sturdy Satellite Pro R50 makes an elegant portable office for busy execs on the go. The ergonomically designed chassis is easy to carry and use, measuring only 24 mm slim.
  • Proven reliability
    The R50 is built to handle the rough and tumbles of life in the office and on the road. Toshiba's Highly Accelerated Life Testing (HALT) includes drop, impact and spill tests to build in world-class reliability.
  • Portable with an odd
    Unlike many ultraportable, the Satellite Pro R50 features a built-in DVD SuperMulti Drive, capable of reading and writing the most popular disc formats.
Dynabook Toshiba Satellite Pro R50-B-12V - 15.6" - Intel Core i5 - 4210U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 8.1 64-bit
Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4400
Input Device
ClickPad
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 6.42 hours
Black, tile black (keyboard)
37.9 cm x 25.8 cm x 2.395 cm
2.3 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4210U / 1.7 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Sound
Stereo speakers, microphone
High Definition Audio, DTS Sound
Input
Keyboard, ClickPad
Numeric Keypad
Multi-touch clickpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
45 Wh
Run Time
Up to 6.42 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
2 x USB 3.0 , LAN , VGA , Headphone/microphone combo jack , HDMI , USB 2.0
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Toshiba PC Health Monitor, Toshiba Eco Utility, EverNote, Toshiba Media Player, Toshiba Function Keys, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription), CyberLink MediaStory
Case Material
Polycarbonate ABS
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
Power adapter
Localization
2.3 kg
Sustainability Information
ENERGY STAR Certified
Get more from your purchase from one of our essential accessories
9QTM StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £85.01
9QTM StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £76.92
