Every professional needs a laptop that will help speed through business, not slow it down. That's why the 39.6 cm (15.6") Satellite Pro A50 from Toshiba offers nothing less than multi-tasking at its best. The next generation in an established line of professional Satellite Pro laptops, it uses a high-capacity processor to power through the busiest or most varied of workloads. And with a durable design plus security features built in, you can rely on it to protect your data too.
Speed through multiple tasks
Busy professionals need to multi-task - and their business laptop needs to help them do it. With high-capacity processor, the Satellite Pro A50 lets you power through your workload with ease. So you can just focus on the tasks at hand, even when working with multiple applications or different documents at the same time, to get the job done. -
Faster response to every command
Your laptop shouldn't hold you back. When you want it to do something, you expect a quick reaction. And you can expect nothing less than the fastest response from the Satellite Pro A50. There's no time delay or waiting around. So as soon as you want to boot up, shut down, or open, save and store your files - you can. -
More connections, more freedom
With the flexibility of high-quality wireless, wired and video connections, you have the freedom to work in more ways and places. You can transfer data to other devices, using USB 2.0. Or do it up to 10 times faster with the USB 3.0 ports. It's easy to send large files via Bluetooth, and share your content in professional HD brilliance on a high-resolution display, using HDMI. Even do it wirelessly, with the Intel Wireless Display (WiDi). And if you need fast access to your local network, there's Gigabit LAN too. -
Keep everyday devices in easy reach
No matter how and where you work, it's important to keep your everyday business tools to hand. Plus you gain extra ports for your printer or any other peripherals that you use daily. -
Safe and secure
The Satellite Pro A50 was designed to protect your business-critical information without impacting on your performance. With the Trusted Platform Module (TPM), they safeguard the critical data on your local storage.
- Dynabook Toshiba Satellite Pro A50-C-1GC - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Graphite black, black (keyboard)
- 37.9 cm x 25.8 cm x 2.395 cm
- 2.1 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD SATA
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Palm Rejection Technology, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , LAN , HDMI , Headphone/microphone combo jack , VGA , 2 x USB 2.0
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription)
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, 3D Accelerator
- Included Accessories
- Power adapter
- Localization
- 2.1 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
