This USB-C docking station lets you use a single USB Type-C port on your laptop or tablet to add essential connectivity while charging your device via 65W USB Power Delivery 3.0. The dock enables you to connect your device to a single monitor of your choice between DisplayPort (4K 30Hz) or VGA (1080p 60Hz) video output. For peripheral connectivity the dock features three USB 3.1 Gen 1 (5Gbps) Type-A ports including a BC 1.2 port to power and charge your USB devices, a USB 3.1 Gen (5Gbps) Type-C port, a 3.5mm headset audio port, and Gigabit Ethernet.
Versatile Display Connectivity
The docking station features single video output with DisplayPort or VGA connectivity so you connect to different monitor depending upon your workstation - ideal for home office IT deployment, where different monitors may be used by different users. The DisplayPort connection offers resolutions up to 4096x2160 (4K) 30Hz, while the VGA connection offers resolutions up to 1920x1200/1080p 60Hz. -
Essential Port Connectivity
The docking station utilizes the versatile USB-C port on your computer port to provide a wide range of port connectivity to suit a variety of applications. The dock features: • 3x USB 3.1 Gen 1 (5Gbps) Type-A ports to connect USB peripheral devices, including a single port that supports BC 1.2 with 7.5W (1.5A) for charging tablets & smartphones, and a physically isolated HID USB port (side) that prevents electromagnetic interference (EMI) on your wireless keyboard/mouse adapters. • 1x USB 3.1 Gen 1 (5Gbps) Type-C port to connect USB peripheral devices. • 1x Gigabit Ethernet port with PXE boot and WoL to connect to a wired Local Area Network (LAN). • 1x 3.5mm 4-position CTIA/OMTP TRRS Audio Jack to connect a 3.5mm headset. -
The docking station includes a 119.9W power adapter and supports 65W USB power delivery. This enables the dock to charge your connected laptop or tablet. Plus, the added power enables one of the USB-A ports to support BC 1.2, for charging tablets and smartphones. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB C Dock, USB-C to DisplayPort 4K 30Hz or VGA, Mini USB-C Laptop Docking Station with 65W Power Delivery Pass-Through Charging, 4-Port USB 3.1 Gen 1 Hub, GbE - Universal USB Type C Port Replicator (DKM30CHDPDUE) - docking station - USB-C 3.2 Gen 1 - VGA, DP - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB-C 3.2 Gen 1
- Video Interfaces
- VGA, DP
- 14.5 cm x 9.1 cm x 2.7 cm
- 313 g
- Space grey
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 110-120 V
- TAA Compliant
- 3-year warranty
- Product Type
- Docking station
- 14.5 cm
- 9.1 cm
- 2.7 cm
- 313 g
- Enclosure Colour
- Space grey
- Localisation
Video
- Max Resolution Details
- 4096 x 2160 - 30 Hz (DisplayPort only) , 1920 x 1200 - 60 Hz (VGA only)
- Data Link Protocol
- USB 3.2 Gen 1
- 1 x USB-C 3.2 Gen 1 - 24 pin USB-C , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm 4-pole , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DisplayPort - 20 pin DisplayPort (1.2) , 1 x USB-C 3.2 Gen 1 with Power Delivery (65W) - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - external - 1 m
- Security lock slot (cable lock sold separately), wake on LAN, LED indicator, Preboot Execution Environment (PXE) support, full duplex support, plastic housing, 65W power delivery (pass-through)
- Security Slot Type
- Kensington nano security slot / Kensington security slot
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
- TAA Compliant
- Power Device
- Power adapter
- Voltage Required
- AC 110-120 V
- OS Required
- Google Chrome OS, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Android 10, Apple macOS Big Sur 11.0, Android 11, Android 9.x, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0, Linux 3.5.x or later LTS versions only
- Limited warranty - 3 years
- Shipping Width
- 24.7 cm
- Shipping Depth
- 16.8 cm
- Shipping Height
- 9.3 cm
- Shipping Weight
- 1.3 kg
- 0 °C
- 50 °C
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.72 |
StarTech.com 10m Active DisplayPort Cable - DP to DP M/M | In Stock | £35.51 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £16.29 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.47 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.55 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £9.82 |
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.06 |
StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA | In Stock | £14.35 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.26 |
StarTech.com 3ft/1m USB-C Cable with USB-A Adapter - Hybrid USB C Cable | In Stock | £21.96 |
