Create a clutter-free workspace by mounting your docking station or hub, freeing up space on your desktop. This docking station mount makes it easy to mount a compatible StarTech.com dock or hub to the wall, under your desk or counter, or to another solid surface.
Made in Canada, the sturdy and durable dock and hub mount is engineered from 10 gauge steel (3.3 mm thick).
Wall mount your laptop docking station or hub to free up space in business offices, commercial spaces, warehouses and industrial environments. You can also mount it under your desk to tuck it away, while still allowing easy access. It's also ideal for space-constrained areas, including hot desks and shared workstations, mobile and wall-mounted workstations, and home offices.
This innovative mount is designed to work exclusively with compatible StarTech.com products including: Dual 4K Universal Docking Station - USB-C / USB 3.0 - 100W PD (DK30C2DPEP); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 100W PD (DK30C2DPEPUE); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 60W PD (DK30C2DPPD); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 60W PD (DK30C2DPPDUE); Thunderbolt 3 Dock with USB-C Laptop Compatibility (TB3CDK2DP); Thunderbolt 3 Dock with USB-C Laptop Compatibility (TB3CDK2DPUE); 4-Port USB-C 10Gbps Hub - USB 3.1 to 3x USB-A + 1x USB-C (HB31C3A1CS); 4-Port USB-C 10Gbps Hub - USB 3.1 to 4x USB-A - Self Powered (HB31C4AS); 3-Port USB-C Hub with GbE - USB 3.1 (10Gbps) (HB31C2A1CGS) .
The docking station mounting kit, complete with mounting plate and screws, makes it easy to mount your compatible dock or hub to a flat surface.
- StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Plate - mounting plate
- Product Type
- Mounting plate
- Placing / Mounting
- Wall mountable, under-desk mountable
- Package Content
- 4 M3x5mm countersunk screws, 4 #5-20 x 5/8" wood screws
- Black
- Product Material
- 10 gauge steel
- 6 cm x 12 cm x 0.33 cm
- 180 g
- 5-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB31C2A1CGS, HB31C3A1CS, HB31C4AS, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP
- Product Type
- Mounting plate
- Product Material
- 10 gauge steel
- Package Content
- 6 cm
- 12 cm
- 0.33 cm
- 180 g
- Shipping Dimensions (WxDxH) / Weight
- 12.5 cm x 22.5 cm x 1 cm / 186 g
- Black
- RoHS, REACH
- TAA Compliant
- Limited warranty: - 5 years
- Designed For
StarTech.com Adjustable CPU Wall Mount | In Stock | £37.24 |
StarTech.com Thin Client Mount - VESA | In Stock | £26.29 |
StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter | In Stock | £70.99 |
StarTech.com 4-Port USB C Hub USB 3.1 Gen 2 (10Gbps) 3x USB-A & 1x USB-C | In Stock | £66.75 |
StarTech.com 4-Port USB C Hub - USB 3.1 Gen 2 (10Gbps) - 4x USB-A Powered | In Stock | £66.05 |
StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA | In Stock | £14.35 |
StarTech.com PC Wall Mount Bracket/Holder | In Stock | £66.05 |
