StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C
Quicklinx: FBM1WS00 Mfr#: M2E1BMU31C
Type: Storage enclosure
HD Size: M.2
Power Supply: [N/A]
£55.05 ex VAT
£66.06 inc VAT
This compact M.2 NVMe SSD Enclosure for PCIe SSDs is a highly portable, high-performance data storage solution for your USB-C or Thunderbolt 3 enabled devices.
Leverage the high speeds of your M.2 NVMe drive, with this external SSD enclosure. It delivers USB 3.1 Gen 2 read/write speeds up to 10Gbps, which is nearly twice the capability of traditional M.2 SATA enclosures.
This enclosure also features ventilation holes to help dissipate heat, ensuring an optimal operating temperature and helping to preserve performance.
This slim, pocket-sized enclosure for PCIe based NVMe is specially designed for mobility, with a small form-factor design that fits easily into your laptop bag. Its lightweight, yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move.
The M.2 NVMe enclosure works with tablets, laptops, desktop computers and hosts that are equipped with USB Type-C and Thunderbolt 3 ports. It's also backward compatible with USB 3.1 Gen 1, making it a convenient solution for the office or other workplace environments.
Additionally, the enclosure supports plug-and-play installation, making it the perfect accessory for professionals on the go.
StarTech.com USB-C (10Gbps) to M.2 NVMe SSD Enclosure - Portable M.2 PCIe Aluminum Case - 1GB/s Read & Write - Mac & PC - storage enclosure - M.2 Card - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - M.2 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Data Transfer Rate
10 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
10.85 cm x 4 cm x 1.3 cm
65 g
M.2
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic, aluminium
Storage Controller
M.2 Card
Data Transfer Rate
10 Gbit/s
Supported Devices
Solid state drive
1
ASMedia ASM2362
Bays
1 x PCIe 3.0 - NGFF B + M key
1 x USB 3.1 (Gen 2) - 24 pin USB-C
Screwdriver
1 x USB-C cable - external - 50 cm
USB powered, UASP transfer protocol, TRIM support, 4Kn drive compatible
MTBF
233,398 hours
FCC, RoHS, WEEE
10.85 cm
4 cm
1.3 cm
65 g
Shipping Weight
200 g
10 - 90%
FBM1 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
FBM1 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.98
FBM1 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £23.56
FBM1 StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £32.12
FBM1 StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £21.56
FBM1 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £35.34
FBM1 StarTech.com M.2 to U.2 Adapter In Stock £26.40
FBM1 StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £15.19
FBM1 StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £10.20
FBM1 StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £28.73
FBM1 StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £73.58
FBM1 StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure In Stock £59.24
FBM1 StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £54.80
FBM1 StarTech.com 4x M.2 PCIe to TB3 Enclosure In Stock £342.85
HD Size: M.2
Power Supply: [N/A]
