StarTech.com USB PCIE/SATA M.2 Enclosure
Quicklinx: GVKWWS00 Mfr#: M2-USB-C-NVME-SATA
Type: Storage enclosure
HD Size: M.2
Power Supply: [N/A]
20 In Stock
£54.80 ex VAT
£65.76 inc VAT
Turn your PCIe M.2 NVMe or SATA AHCI M.2 SSD into a highly portable, USB-based external storage solution. This enclosure features USB 3.1 Gen 2 (10Gbps) with UASP support & PCIe 3.0 delivering real read/write data transfer speeds up to 1GB per second. Working with both PCIe and SATA based drives, this enclosure ensures compatibility with many M.2 drives, supporting both M-Key (PCIe) and B+M-Key (SATA) drives sized 2230/2242/2260/2280. The enclosure is also forward compatible with PCIe 4.0 based drives, at reduced PCIe 3.0 performance. USB 3.1 Gen 2 10Gbps (also known as USB 3.2 Gen 2x1) is backward compatible with USB 3.1 Gen 1 5Gbps (also known as USB 3.0), USB 2.0, and USB 1.1.
  • All-in-One M.2 and USB Solution
    With compatibility for both PCIe NVMe and SATA based M.2 drives, this enclosure solves the common challenge of identifying which enclosure is compatible with your M.2 drive. Regardless of whether your M.2 drive is SATA or PCIe NVMe based, you can rest assured that this enclosure will provide a high-performance solution for turning your M.2 drive into a portable external enclosure. For further compatibility the enclosure works with multiple drive lengths supporting 2230, 2242, 2260 and 2280mm drives including Samsung (850, 860, 870, 950, 960, 970) Kingston, Seagate, Western Digital (WD), HP, and Intel SSD drives. For multiplatform support this enclosure, the enclosure features a USB-C host connection, and includes two different 12 in. (30 cm) host cables, a USB-C to USB-C cable and a USB-C to USB-A cable. This combined with the backward compatibility of the USB protocol, ensures that this M.2 enclosure will work with virtually any computer, whether it's USB-A, USB-C or Thunderbolt 3/4.
  • Tool-Free Drive Installation
    The external M2 SATA or M.2 NVMe SSD enclosure case supports driverless plug-and-play installation and features tool-less drive installation, so you can install your drive with no tools required.
  • Unparalleled Performance
    Leverage the high speeds of your M.2 NVMe or SATA drive, with this external SSD enclosure. It delivers USB 3.2 Gen 2x1 maximum theoretical throughput of 10Gbps, which is twice the throughput of USB 3.2 Gen 1x1 at 5Gbps. The enclosure also supports PCIe 3.0 which when combined with an M.2 NVMe drive takes full advantage of the throughput available to USB 3.2 Gen 2x1. This fan-less aluminum enclosure features ventilation holes for maximum heat dissipation, ensuring your drive operates noiselessly at an optimal temperature to preserve performance and protect your drive from overheating damage.
  • Durable and Portable
    This slim, pocket-sized enclosure for PCIe NVMe or SATA based M.2 drives is specially designed for mobility, with a small form-factor design that fits easily into your laptop bag. Its lightweight, yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move. M2-USB-C-NVME-SATA is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure, Tool-free M.2 PCIe/SATA NGFF SSD Enclosure, Portable Aluminum Case, USB Type-C & USB-A Host Cables, For 2230/2242/2260/2280 - Works w/ Thunderbolt 3 (M2-USB-C-NVME-SATA) - storage enclosure - M.2 Card (PCIe NVMe & SATA) - USB-C 3.2 (Gen 2)
Storage enclosure - external
Bus Type
USB-C 3.2 (Gen 2)
Space grey
Expansion Bays
1 x internal - M.2 NGFF 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
10 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
Power Source
USB bus
10.5 cm x 3.5 cm x 1.4 cm
52 g
M.2
Host Bus
USB-C 3.2 (Gen 2)
Product Material
Aluminium
Space grey
Storage Controller
Data Transfer Rate
10 Gbit/s
Supported Devices
Solid state drive
1
Bays
1 x SATA 6Gb/s / PCIe 4.0 (NVMe) - M.2 M+B/M Key (internal)
1 x USB 3.2 (Gen 2) - 24 pin USB-C
Thermal pad, SSD fastener pegs
1 x USB-C to USB-C cable - external - 30 cm , 1 x USB-C to USB-A cable - external - 30 cm
LED indicator, supports AHCI mode, TRIM support, 4Kn drive compatible
MTBF
112,000 hours
UASP (USB Attached SCSI Protocol)
Power Source
USB bus
10.5 cm
3.5 cm
1.4 cm
52 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
2.8 cm
Shipping Weight
75 g
10 - 90% (non-condensing)
GVKW StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
GVKW StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.98
GVKW StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £15.19
GVKW StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £10.20
HD Size: M.2
Power Supply: [N/A]
