StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC)
Quicklinx: 82HRWS00 Mfr#: SFPG1320C
Type: Modules
£43.94 ex VAT
£52.72 inc VAT
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPG1320C Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC - 20 km (12.4 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Single-Mode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1310nm single-mode SFP module is compatible with Cisco equipment.
StarTech.com Cisco GLC-LH-SMD Compatible SFP Module 1000BASE-LH 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver 1GE Gigabit Ethernet SFP LC 20km, 1310nm, DDM, Cisco Firepower, IE2000 - Lifetime Warranty (SFPG1320C) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LH
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
20 km
0.9 cm x 6.5 cm x 1.4 cm
25 g
P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, IES101G2SFPW, IES101GP2SFW, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-LH
1GbE
Optical Wave Length
1310 nm
20 km
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-LH - LC single-mode
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, MSA
0.9 cm
6.5 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
82HR StarTech.com Gb MM SFP Fiber Transceiver In Stock £42.40
82HR StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £18.18
82HR StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £42.81
82HR StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £43.94
82HR StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £26.11
82HR StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £26.34
82HR StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £38.70
82HR StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.49
82HR StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £26.56
82HR StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.89
82HR StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £22.15
82HR StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £160.38
82HR StarTech.com Fiber Media Converter - Open In Stock £48.56
82HR StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £368.50
Type: Modules
