Add, replace or upgrade SFP modules on gigabit fiber equipment. The SFPSXMM Gigabit 850nm Multi Mode SFP Fiber Optical Transceiver - LC 550m is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to increase performance and connectivity of your fiber-connected network devices.
Using a short wavelength (850nm) VCSEL laser diode, enabling a maximum cable distance of 550m (0.3 miles) over multi mode fiber, this Small Form Factor Pluggable (SFP) Gigabit Multi Mode module can be installed into any fiber networking devices with an MSA compliant SFP port, providing a simple solution to upgrade existing network devices to connect to remote locations using LC terminated multimode fiber.
Delivering convenience and scalability, the optical transceiver allows you to install the multimode LC module without interrupting network traffic or requiring a device reboot.
- StarTech.com MSA Uncoded Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, 1Gbps Mini GBIC Module - Lifetime Warranty (SFPSXMM) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- 1.3 cm x 5.5 cm x 0.9 cm
- 18 g
- 2-year warranty
- Designed For
- P/N: MCM1110SFP
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 1 Gbps
- 850 nm
- 550 m
- Full duplex capability
- IEEE 802.3z
- 1 x Ethernet 1000Base-SX - LC multi-mode x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- CSA, UL, TUV, FCC, RoHS
- 1.3 cm
- 5.5 cm
- 0.9 cm
- 18 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 95%
- Designed For
- P/N: MCM1110SFP
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.22 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £27.07 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £17.35 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £21.31 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £18.84 |
StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC | In Stock | £37.80 |
StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) | In Stock | £42.81 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £43.94 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £26.11 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £26.34 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £160.38 |
StarTech.com Fiber Media Converter - Open | In Stock | £48.56 |
StarTech.com Gb RJ45 Copper SFP - 10 Pack | In Stock | £266.91 |
StarTech.com Gigabit RJ45 Copper SFP | In Stock | £40.14 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £368.50 |
StarTech.com Cisco GLC-TE Compatible SFP Copper Module - 1000BASE-T | In Stock | £48.71 |
