This 4-Port HDMI Video Switch enables four HDMI sources to connect to a single HDMI input on a display.
8K 60Hz Resolution
The HDMI Switcher supports resolutions of up to 8K 60Hz. In addition, it supports lower resolutions at higher refresh rates, such as 4K 144Hz, 4K 120Hz, and 1080p 240Hz. This Video Switch is HDMI 2.1 complaint and supports features such as Variable Refresh Rate (VRR), Auto Low-Latency Mode (ALLM), and Consumer Electronics Control (CEC). It is backwards compatible with HDMI 2.0 (and lower) devices. -
Automatic or Manual Operation
The 8K Video Switch features three options for selecting the source device. Automatic mode detects and selects the most recently activated source device or it will revert to the last active source device. Manual mode selects the desired port, using the push buttons, or with the included remote control (batteries not included). The remote control can enable or disable the automatic switching mode and it can disable the IR functionality. -
Flexible Installation Options
Use the included USB wall charger and 2.5ft (78cm) USB Micro-B cable to power the unit. If a wall outlet is unavailable, the 8K Switch can be powered through a 5V 1A USB port as well. The included mounting kit and rubber feet enable versatile installation options. The metal housing enhances durability, making it suitable for installation and use in a variety of environments. This product is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
- StarTech.com 4-Port 8K HDMI Switch, HDMI 2.1 Switcher 4K 120Hz HDR10+, 8K 60Hz UHD, HDMI Switch 4 In 1 Out, Auto/Manual Source Switching, Remote Control and Power Adapter Included - 7.1 Channel Audio/eARC (4PORT-8K-HDMI-SWITCH) - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Performance
- Bandwidth: 48 Gbps
- 7.1 channel audio support, metal housing, Dolby TrueHD support, DTS-HD Master Audio support, Dolby Atmos support, DTS:X support, auto-switching, HDR10+ support, push button, VRR, ALLM
- HDCP 1.4, HDCP 2.2, HDCP 2.3
- Power
- AC 100-240 V 0.3 A
- 13.6 cm x 6.1 cm x 1.4 cm
- 150 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Performance
- Max Resolution
- 8K @ 60 Hz
- Status Indicators
- Port status, power, auto, infrared
- 4 x HDMI input Type A , 1 x HDMI output Type A , 1 x micro-USB (power only) Type B
- Power Device
- External power adapter
- Power Provided
- DC 5 V - 1 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 0.3 A
- 5 Watt
- Black
- Included Accessories
- Remote control, 4 rubber feet, mounting kit
- Cables Included
- 1 x USB-A to Micro-USB Type B cable - 78 cm
- RoHS, WEEE, CEC, RCM
- 13.6 cm
- 6.1 cm
- 1.4 cm
- 150 g
- Shipping Width
- 17.9 cm
- Shipping Depth
- 12.3 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 420 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 70 °C
- 5 - 90% RH (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 80 °C
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £15.88 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £20.72 |
StarTech.com 16ft Ultra High Speed HDMI 2.1 | In Stock | £39.74 |
StarTech.com 12ft Ultra High Speed HDMI 2.1 | In Stock | £33.33 |
StarTech.com 2-Port 8K 60Hz HDMI Switch | In Stock | £49.13 |
