StarTech.com 5m USB 3.0 Active Extension Cable - M/F
Quicklinx: 80HSWS00 Mfr#: USB3AAEXT5M
Length: 5m
23 In Stock
£83.33 ex VAT
£99.99 inc VAT
Extend the distance between a computer and a USB 3.0 device by an additional 5 meters. The USB3AAEXT5M, 5-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 5-meters (16-feet). An all in one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 4 of these cables can be daisy-chained together, allowing the connection to be extended a total of 20-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable. The USB3AAEXT5M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
StarTech.com 16.4ft Active USB 3.0 Extension Cable with AC Power Adapter - Shielded - Male to Female USB USB 3.1 Gen 1 Type A (5Gbps) Extender (USB3AAEXT5M) - USB extension cable - USB Type A to USB Type A - 5 m
USB extension cable
Active cable (signal regeneration)
Length
5 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
USB / USB 2.0 / USB 3.0
P/N: PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S7, ST7300U3M, ST7300USB3B, SVA5H2NEUA, USB3SAA3MBK
USB extension cable
Plated Connector
Nickel
Length
5 m
Connector
USB / USB 2.0 / USB 3.0, FCC, RoHS
80HS StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £79.43
80HS StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £83.33
80HS StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £117.37
80HS StarTech.com 6in USB 3.0 Extension Cable In Stock £5.31
80HS StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.87
80HS StarTech.com DC Power Adapter - 5V, 2A In Stock £10.25
80HS StarTech.com USB Extender Hub, 10m, USB 3.0 In Stock £144.67
Length: 5m
