StarTech.com 450 Watt ATX12V 2.3 80 Plus Bronze Computer Power Supply w/ Active PFC
Quicklinx: 93J3WS00 Mfr#: ATX2PW450BR
The ATX2PW450BR 450 watt 80 Plus Bronze power supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at an 82% to 85% efficiency between 20% and 100% load, 80 Plus Bronze power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
StarTech.com 450 Watt ATX12V 2.3 80 Plus Bronze Computer Power Supply w/ Active PFC - power supply - 450 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
Input Voltage
AC 115/230 V
Output Voltage
+3.3, ±5, ±12 V
Power Capacity
450 Watt
Output Current
+12V1 - 37 A , +12V2 - 37 A , +12V3 - 37 A , +12V4 - 37 A , +3.3V - 20 A , +5V - 20 A , -12V - 0.5 A , +5VSB - 2.5 A , -5V - 37 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
PSU Form Factor
ATX
Input Voltage
AC 115/230 V
Input Voltage Range
AC 110 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, ±5, ±12 V
Power Capacity
450 Watt
Output Current
80 PLUS Bronze
Cooling System
120 mm fan
Over current protection, over voltage protection, overpower protection, short-circuit protection, non-modular
UL, FCC, RoHS
10 - 90%
15 cm
14 cm
8.6 cm
