HPE 900W AC 240VDC Power Input Module
Quicklinx: F5PYWS00 Mfr#: 775595-B21
Power Rating: 900Watt
Hurry, only 3 left in stock!
£54.87 ex VAT
£65.84 inc VAT
Express delivery Order within the next 12 hours for delivery tomorrow
Looking for high-efficiency power solutions at an entry-level price for your ProLiant Gen9 Essential Server? HPE Entry-Level Power Supplies offer an optimized set of features with options for both redundant and non-redundant power configurations. The HPE 550W FIO Power Supply offers Silver-certified 80 Plus power efficiency up to 89% with an optimized set of features for non-redundant power configurations. The HPE 900W Gold Redundant AC Power Input Module with Power Backplane can be configured to support power redundancy in ProLiant servers that offer only a single power supply bay, providing additional protection against power loss. With an 80 Plus Gold power efficiency rating up to 92%, this power option helps to reduce operating expenses while protecting against trapped power capacity in the data center. Hot-plug AC power input modules allow for better serviceability with fast and easy deployment and replacement.
  • Optimized, High Efficiency Power Supply
    The HPE 550W FIO Power Supply is a non-redundant, Silver-certified 80 Plus power option (up to 89% efficiency) offering an optimized set of features at an entry-level price.Compatible across a wide range of HP ProLiant Gen9 Essential Servers providing a common power supply spares strategy that helps to reduce data center costs.
  • Innovative, High Efficiency Entry-Level Power Supply with Support for Power Redundancy
    The HPE 900W Gold Power Supply can be configured to support power redundancy in ProLiant servers that offer only a single power supply bay, providing additional protection against power loss.Gold certified 80 Plus power efficiency rating, up to 92% efficiency, reduces operating expenses and trapped power in the data center.Hot-plug AC power input modules allow for better serviceability with fast and easy deployment and replacement.Compatible across a wide range of HP ProLiant Gen9 Essential Servers providing a common power supply spares strategy that helps to reduce data center costs.
HPE Power Input Module - power supply - hot-plug / redundant - 900 Watt - 986 VA
Power supply - hot-plug / redundant - plug-in module
80 PLUS Certification
80 PLUS Gold
350 g
Input Voltage
AC 100-127/200-240 V
Power Capacity
900 Watt / 986 VA
Pricing Type
CTO
10.72 cm x 3.7 cm x 5.18 cm
ProLiant DL180 Gen9 (900 Watt), DL180 Gen9 Base (900 Watt), DL180 Gen9 Entry (900 Watt), DL180 Gen9 Storage (900 Watt), DL20 Gen9 (900 Watt), DL20 Gen9 Entry (900 Watt), DL20 Gen9 Performance (900 Watt), DL20 Gen9 Solution (900 Watt), DL80 Gen9 Entry (900 Watt)
Input Voltage
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Power Capacity
900 Watt / 986 VA
Efficiency
92%
80 PLUS Gold
UL, TUV, C-Tick, BSMI, cUL, CCC, KCC, CISPR
Pricing Type
CTO
5 °C
50 °C
5 - 95% (non-condensing)
10.72 cm
3.7 cm
5.18 cm
350 g
HPE ProLiant DL180 Gen9 (900 Watt), DL180 Gen9 Base (900 Watt), DL180 Gen9 Entry (900 Watt), DL180 Gen9 Storage (900 Watt), DL20 Gen9 (900 Watt), DL20 Gen9 Entry (900 Watt), DL20 Gen9 Performance (900 Watt), DL20 Gen9 Solution (900 Watt), DL80 Gen9 Entry (900 Watt)
Brand: HPE
Stock Status: While stocks last
Stock Status: Clearance
