StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor
Quicklinx: FKF3WS00 Mfr#: MST14DP123DP
Type: DisplayPort
Ports: 3
Data Transfer Rate: [N/A]
Managed: No
POE: No
20 In Stock
£54.36 ex VAT
£65.23 inc VAT
3 x 4K Multi-Monitor Video Splitter Windows HDR. This 3-port DisplayPort MST hub lets you create a high-performance workstation by connecting three DisplayPort monitors to your DisplayPort device, helping to increase and maximize your productivity. The multi-monitor splitter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Incredible Picture Quality
Supporting four times the resolution of 4K, this DP 1.4 MST hub delivers the stunning quality of UHD at resolutions up to 7680×4320 at 30Hz on a single monitor and supports multi-monitor applications at lower resolutions and refresh rates, enabling a dynamic work environment whether you're in the office, at home or traveling.
Display 1
Display 2
Display 3
8K (7680x4320) @ 30Hz
X
X
5K (5120x2880) @ 60Hz
1080p (1920x1080) @ 30Hz
X
4K (3840x2160) @ 60Hz
4K (3840x2160) @ 30Hz
2K (2560x1600) @ 60Hz
1080p (1920x1080) @ 60Hz
Both your source and destination must support DisplayPort 1.4 in order to achieve maximum resolution (8K 30Hz).
Lower resolutions and refresh rates may also be supported.
Multi-Tasking Made Easy
This DisplayPort to 3x DisplayPort MST hub enables you to daisy chain three displays to your DP computer, making multi-tasking much easier. Using this multi-monitor video splitter, you can mirror your display onto multiple monitors, stream independent content to each display or extend your screen to create a video wall effect.
Hassle-Free Setup
Multi-stream transport offers an easy setup, by natively working on any Windows device. It offers plug-and-play installation with no drivers or software required. Additionally, the DisplayPort MST hub is bus-powered (with the included micro-USB cable), creating an ultra-portable solution for business and IT professionals.
MST14DP123DP is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
  • Incredible Picture Quality
    Supporting four times the resolution of?4K, this?DP 1.4 MST hub?delivers the stunning quality of UHD at resolutions up to 7680×4320 at 30Hz on a single monitor and supports multi-monitor applications at lower resolutions and refresh rates, enabling a dynamic work environment whether you're in the office, at home or traveling. Both your source and destination must support DisplayPort 1.4 in order to achieve maximum resolution (8K 30Hz). Lower resolutions and refresh rates may also be supported.
  • Multi-Tasking Made Easy
    This DisplayPort to 3x DisplayPort MST hub enables you to connect three displays to your DP computer, making multi-tasking much easier. Using this multi-monitor video splitter, you can mirror your display onto multiple monitors, stream independent content to each display or extend your screen to create a video wall effect.
  • Hassle-Free Setup
    Multi-stream transport offers an easy setup, by natively working on any Windows device. It offers plug-and-play installation with no drivers or software required. Additionally, the DisplayPort MST hub is bus-powered (with the included micro-USB cable), creating an ultra-portable solution for business and IT professionals. MST14DP123DP is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
StarTech.com 3-Port Multi Monitor Adapter, DisplayPort 1.4 to 3x 4K DP Video Splitter, Triple or Dual 4K, Laptop/Desktop DisplayPort MST Hub for Multiple Monitors, Windows Display Adapter - Multi Stream Transport (MST14DP123DP) - video/audio splitter - 3 ports
Video/audio splitter - 3 ports
Subtype
DisplayPort
Ports
4 x DisplayPort
USB powered, plastic housing, latching, 7.1 channel audio support, MST support, HDR support
10.5 cm x 4.3 cm x 1.4 cm
53 g
Grey, black
Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
3-year warranty
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
4 x DisplayPort
Max Resolution
7680 x 4320 @ 30 Hz
3 x DisplayPort output , 1 x DisplayPort input
Grey, black
Micro-USB cable
FCC, RoHS, REACH, DisplayPort 1.4
10.5 cm
4.3 cm
1.4 cm
53 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
107 g
Limited warranty - 3 years
70 °C
5 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
55 °C
FKF3 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
FKF3 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £23.98
FKF3 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
FKF3 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.98
FKF3 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.80
FKF3 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
FKF3 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.29
FKF3 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.05
FKF3 StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £14.89
FKF3 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
FKF3 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £17.05
FKF3 StarTech.com DP 1.4 to Dual HDMI MST Hub In Stock £55.95
FKF3 StarTech.com 2-Port DisplayPort MST Hub In Stock £41.24
FKF3 StarTech.com 3-Port DisplayPort MST Hub In Stock £70.19
Type: DisplayPort
Ports: 3
Managed: No
POE: No
