StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub
Quicklinx: 6LD0WS00 Mfr#: SV231DD2DUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
£197.20 ex VAT
£236.64 inc VAT
Share a keyboard, mouse and dual DVI displays/monitors between 2 multimedia computers. The SV231DD2DUA 2-port Dual DVI USB KVM Switch allows two PCs, each with dual DVI video outputs, to share two monitors, one microphone and set of speakers, one keyboard and one mouse as well as two other USB peripherals.
An ideal solution for graphic designers, CAD/CAM designers or educational and financial institutions, the dual view KVM Switch allows you to instantly switch back and forth between dual DVI display PCs at the touch of a button, while maintaining professional level video quality on both monitors. The dual DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals such as thumb drives, external hard drives or web cams to be shared between attached systems - eliminating duplicate peripheral costs.
This KVM switch supports DVI-D (digital) signaling only and it is recommended wherever possible to use DVI-D cabling across all PC to KVM and KVM to Console connections to ensure proper function.
StarTech.com DVI KVM Switch with Audio & USB 2.0 Hub - 2-Port USB KVM Switch - 1920 x 1200 - Dual Monitor KVM Switch (SV231DD2DUA) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
16.3 cm x 10 cm x 6.6 cm
0.75 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Status Indicators
Port status
4 x DVI-D , 2 x USB 2.0 Type B , 4 x audio mini-jack , 2 x DVI-D , 2 x audio mini-jack , 4 x USB 2.0 Type A
External power adapter
FCC, RoHS
16.3 cm
10 cm
6.6 cm
0.75 kg
Limited warranty - 3 years
6LD0 StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £10.71
6LD0 StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £269.04
6LD0 StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £277.79
6LD0 StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £197.20
6LD0 StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub In Stock £177.08
6LD0 StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
6LD0 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.94
6LD0 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.82
6LD0 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.59
6LD0 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.74
6LD0 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.39
6LD0 StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £308.73
6LD0 StarTech.com 2 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £349.21
6LD0 StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
6LD0 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
6LD0 StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £554.15
Connectivity: KVM
Ports: 2
