Wall-mount your server or networking equipment sideways, for easy access. The RK1019SIDEM Side-mounted Wallmount Open Frame Rack/Cabinet is a 10U rack that enables you to mount 19in (wide) servers, A/V or network equipment facing perpendicular to a wall, for easy access to mounted devices and equipment. The cabinet/rack open access to both the front and back of your devices, making it easy to adjust cabling, view LEDs and access configuration buttons as needed.
Plus, the nature of the sidemount configuration allows for deeper mounting depths than typical wallmount racks.
Constructed of high-quality SPCC cold-rolled steel, for strength and durability, the open frame rack allows for maximum airflow while still supporting a maximum weight capacity of 159 kg (350 lbs). The wall mount rack also ships complete with all of the M5 screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
- StarTech.com 10U 19in Wall Mount Side Mount Open Frame Rack Cabinet - rack - 10U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 10U
- Product Material
- Steel
- 53.7 cm x 56 cm x 56.8 cm
- 19.4 kg
- Limited lifetime warranty
- Product Type
- Rack
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 10U
- 53.7 cm
- 56 cm
- 56.8 cm
- 19.4 kg
- Black
- Weight Limit
- 159 kg
- Mounting Kit
- Included
- EIA-310-D, UL, RoHS
- Limited warranty: - lifetime
