StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks
Quicklinx: 97RHWS00 Mfr#: 4POSTRACK42
Depth (mm): 59.18cm
Type: Floor standing
Width (mm): 60cm
U Height: 42U
20 In Stock
£252.52 ex VAT
£303.02 inc VAT
Store your servers, network and telecommunications equipment in this adjustable 42U open-frame rack. The 4POSTRACK42 42U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 42U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1320lbs (600kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete rack solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securing the rack to the floor if needed, providing you with many options to customize the rack to fit your environment.
StarTech.com 42U 19" Open Frame Server Rack, 4 Post Adjustable Depth 23-41" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK42) - rack - 42U
Rack
Package Content
16 M6 screws, 4 vertical rack rails, 24 mounting screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 50 PVC cup washers, 24 cable management hooks, 4 casters, 4 x levelling feet, 32 M6 flat washers, 16 M6 flange nuts, 50 M6 screws, 50 M6 cage nuts
Height (Rack Units)
42U
Product Material
Steel
60 cm x 59.18 cm x 197.1 cm
38.5 kg
P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
Rack
Product Material
Steel
Package Content
Height (Rack Units)
42U
60 cm
59.18 cm
197.1 cm
38.5 kg
Weight Limit
600 kg
RoHS, DIN 41494, IEC 60297-3-100
Limited warranty: - 2 years
97RH StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £490.32
97RH StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
97RH StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £99.99
97RH StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £48.25
97RH StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
97RH StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
97RH StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £34.53
97RH StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £551.61
97RH StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £337.14
97RH StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
97RH StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
97RH StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
97RH StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
97RH StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £28.76
97RH StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £575.96
97RH StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £292.39
97RH StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £319.01
97RH StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £657.69
97RH StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £120.51
97RH StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £68.86
97RH StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £88.30
97RH StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
97RH StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £77.10
97RH StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £92.81
97RH StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.50
97RH StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £45.85
97RH StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £39.89
97RH StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £53.98
97RH StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.31
97RH StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
97RH StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £252.52
97RH StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
97RH StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £20.58
97RH StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £237.02
97RH StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £25.63
97RH StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £205.22
97RH StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £65.84
97RH StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.13
97RH StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
97RH StarTech.com 100 Pkg M5 Cage Nuts In Stock £34.53
97RH StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
97RH StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
97RH StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
97RH StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
97RH StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
97RH StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
97RH StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.55
97RH StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
97RH Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
97RH StarTech.com 19in Cable Management Panel In Stock £24.78
97RH StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.11
97RH StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £225.59
97RH StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £219.17
97RH StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £174.57
97RH StarTech.com M6 Mounting Screws 50Pack In Stock £17.54
Depth (mm): 59.18cm
Width (mm): 60cm
U Height: 42U
