Sony VPL-SW235 WXGA 3000 Lumens Projector
Quicklinx: 9QP6WS00 Mfr#: VPL-SW235
The VPL-SW235 short throw projector has a number of features to present high quality images while keeping low TCO. This includes brightness of 3000 lumen, so images can be clearly seen even in a bright room. Constant brightness function extends the brightness of the projector over a long period of time. While energy-efficient technologies extend lamp replacement time. The projector also needs only 79 cm to display a large 80-inch image on the screen, which fits perfectly in front of a white board leaving plenty of space. With the fuss-free installation and achievement of less glares or shadows during presentation, the short throw projector offers excellent usability.
  • Short throw distance
    The VPL-SW235 offers a 0.46:1 throw ratio that produces a 2.03 m (80-inch) diagonal screen size image from only 79 cm (31-inch) away from the screen.
  • High image quality 3LCD natural and vivid color images
    Thanks to the optical system projecting three basic colors constantly each, the projector offers excellent light efficiency, which ensures colorful and bright images. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. The projector also has an excellent contrast ratio of 3000:1.
  • High brightness of 3000 lumen in high lamp mode
    The VPL-SW235 features three brightness modes for different use - 'High' for naturally white presentations in bright rooms, 'Standard' for everyday use, and 'Low' for video in darkened rooms. The native WXGA (1280 x 800) 16:10 widescreen screen resolution panelist is perfect for presentations direct from a laptop or PC.
  • Energy efficient with long-lasting lamp
    The lamp driver optimally controls the wattage of the lamp and achieves a long-lasting lamp time with the brightness of lamp mode low. The lamp time is extended more than 66%, compared to the previous model.
  • Advanced energy-saving features
    Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in auto light dimming mode saves considerable energy when the projector is left on without being used. During projection, auto picture mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption.
  • Network presentation (LAN/wireless LAN)
    When the projector is installed on a LAN/wireless LAN, presentations can be projected from any PC and Mac on the network. A tablet or smart phone can be connected at the same time. The wireless presentation capability makes it easy to present files from your tablet device or smart phone. You can project JPG, PDF and other supporting formats. Up to four users can project PC/Mac images simultaneously, while up to eight users can connect to one projector.
Sony VPL-SW235 - 3LCD projector - short-throw - LAN
3LCD projector - 720p
Built-in Devices
Speaker
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Short-throw fixed lens
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
315 Watt
36.5 cm x 31 cm x 13.87 cm
4.4 kg
Built-in Devices
Speaker
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
1700 lumens
Image Size
145 cm - 262 cm
Projection Distance
0.55 m - 1.04 m
Throw Ratio
0.46:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Wireless Ready, Vivid Color Control, USB Viewer
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-10 / +10
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Remote control, lithium coin cell battery
1 x VGA cable
315 Watt
36.5 cm
31 cm
13.87 cm
4.4 kg
20 - 80% (non-condensing)
9QP6 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
