The VPL-DX142 is packed with features optimized for the business and education markets at a reasonable price. The projector is compact and lightweight, with its simple design making it very easy to set up.
Sony 3LCD BrightEra panel technology provides bright and colorful projection. Plenty of interfaces allow easy connection, while a choice of Picture modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. There's a range of smart energy-saving features built in, including auto power saving function. And with a recommended lamp replacement time, downtime and maintenance costs are minimized.
Compact, lightweight and stylish design
The VPL-DX142 has a compact and lightweight body with a small footprint and a light weight. This compact, lightweight projector is convenient for carrying around a meeting room or classroom. -
Energy efficient with long-lasting lamp
The lamp driver optimally controls the wattage of the lamp and achieves a long-lasting lamp. The recommended lamp replacement time is extended by 43%, compared to the previous model. -
Advanced energy-saving features
Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto light dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto lamp mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption. -
High image quality 3LCD BrightEra natural and vivid color images
Widescreen XGA (1280 x 800) 4:3 screen resolution, 3LCD BrightEra natural and vivid color images, plus various Picture Modes for optimizing image quality, make the projector one of the best in its class. Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, ensuring colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. -
Various picture modes for optimal picture quality
The projector has six available picture modes for correct picture quality: Dynamic, Standard, Presentation, Blackboard, Game, and Cinema. With six picture modes and three brightness modes combined, the user can select the most suitable picture/brightness combination according to the picture source and environment, to create the optimal image.
- Sony VPL-DX142 - 3LCD projector - portable
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3200 lumens
- Contrast Ratio
- 3000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- Ultra high-pressure mercury 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
- Video Modes
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 277 Watt
- 31.5 cm x 23.05 cm x 7.5 cm
- 2.5 kg
- 3LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 lumens
- Brightness (Reduced)
- 2000 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 1.37 - 1.8:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Display Format
- 2,359,296 pixels (1024 x 768) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
- Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Auto Dimming Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Horizontal
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Power Source
- AC
- Voltage Required
- 277 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 23.05 cm
- 7.5 cm
- 2.5 kg
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
