Fractions of a second matter. The incredibly fast refresh rate of the INZONE M3 puts you a step ahead of your competitors and lets you speed through scenes without lag, delay or judder.
React faster than your opponents. With a refresh rate of up to 240 Hz, you'll gain that vital split-second advantage that helps you track rivals precisely and shoot first. Action is super smooth in Full HD so you see what's happening the moment it happens.
240 Hz and IPS 1 ms GtG, unbelievably fast
Fractions of a second matter. The incredibly fast refresh rate of the INZONE M3 puts you a step ahead of your competitors and lets you speed through scenes without lag, delay or judder. -
Aim precisely, shoot first with 240 Hz refresh rate
React faster than your opponents. With a refresh rate of up to 240 Hz, you'll gain that vital split-second advantage that helps you track rivals precisely and shoot first. Action is super smooth in Full HD so you see what's happening the moment it happens. -
Enjoy rapid action with IPS 1 ms GtG
Perform good on an IPS display with ultra fast 1 ms GtG response speed. Less ghosting and blur allows you to see what's happening with absolute clarity so you can make lightning fast decisions and react immediately. -
DisplayHDR 400 certified, immersive viewing
See a broader range of colors, darker shadows and brighter highlights. With DisplayHDR 400, INZONE M3 reproduces scenes in vivid shades with rich accurate contrast and high peak brightness of 400 nits for more immersive and atmospheric gaming. -
A wide range of vibrant colors for gaming realism
With over 99% coverage of the sRGB spectrum, the INZONE M3 monitor fills your game with a wide range of rich, vibrant colors. More shades and hues make scenes extremely realistic for dramatic, immersive gaming. -
Designed to fit the way you play
Game your way with a versatile design that adapts to your play style. The unique, low depth tripod stand provides total gaming comfort while optimizing desk space for peripherals. -
Easily connect and control your gaming system
Power up your gaming rig and connect all your peripherals in no time. A variety of options including HDMI port, DisplayPort 1.4 and USB Type-C (DisplayPort alternate mode) gives you the connectivity you need.
- Sony INZONE M3 - LED monitor - Full HD (1080p) - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 240 Hz
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1 / 1000:1 (dynamic)
- HDR Capable
- HDR10 / DisplayHDR 400
- Response Time
- 1 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50 - 60 Hz)
- Dimensions (WxDxH) - without stand
- 61.5 cm x 7.3 cm x 36.3 cm
- 4.1 kg
- 1-year warranty
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 400 cd/m²
- Contrast Ratio
- HDR Format
- HDR10
- HDR Certification
- DisplayHDR 400
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 24 - 240 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Japanese, Korean
- Eco-Mode, game mode, Cinema Mode, Black eQualizer, FPS Mode, Flicker Free technology, Crosshair Display, Low Blue Light technology
- 61.5 cm x 7.3 cm x 36.3 cm - without stand
- 4.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 4 Watt
- 2 x HDMI (HDCP) , DisplayPort 1.4 (HDCP) , USB upstream (Type B) , USB upstream (Type A) , 3 x USB downstream (Type A) , Headphones (mini-jack)
Mechanical
- Height, tilt
- Tilt Angle
- 0/+20
- Height Adjustment
- 70 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 21.6 kWh/1000h
- Power Consumption HDR (On mode)
- 31.1 kWh/1000h
- Dimensions & Weight Details
- Without stand - width: 61.5 cm - depth: 7.3 cm - height: 36.3 cm , With stand - width: 61.5 cm - depth: 24.8 mm - height: 47.9 cm - weight: 6.2 kg
- Shipping Width
- 69 cm
- Shipping Depth
- 22.8 cm
- Shipping Height
- 46.2 cm
- Limited warranty - 1 year
