The SMART Board SBID8070i-G4-SMP interactive flat panel features SMART's proprietary DViT (Digital Vision Touch) technology on an LCD screen with e-LED backlight which enables you to select, write erase on the interactive surface. By touching the surface, you can do everything on the interactive flat panel that you can do at your computer, and you can use an array of gestures within applications.
You can also write or draw over any application in digital ink using one of the supplied pens or your finger, and then erase the digital ink using the supplied eraser or your palm. Two users can write or draw at the same time. The interactive flat panel has two presence detection sensors on its frame that can detect people up to 16' (5 m) away. When the sensors detect people in the room, the interactive flat panel turns on. When the sensors no longer detect people in the room, the interactive flat panel turns off.
Features:
Sensors detect and automatically respond to user movements, so the interactive flat panel turns on and stays in active mode when people are near and turns off when no movement is detected.
The 8000 series features a commercial-grade, high-definition display powered by SMART's proprietary DViT (Digital Vision Touch) technology, crisp 1080p images that make it easy to engage students in lessons.
Its high-definition, shadow-free design ensures that lesson content is easy to see.
Two people can simultaneously write, perform mouse functions, erase and manipulate objects on its display - no special tools are required.
The 8000 series enables two people to instantly start working together without having to switch into a separate multiuser mode or work in a confined area.
Use simple, intuitive hand and finger gestures to work with content, including one- and two-finger navigational gestures - such as panning and flicking pages - and object gestures, like zoom, toss and rotate. The 8000 series also supports touch gestures found in Microsoft Windows 7 and Mac OS X Snow Leopard operating systems.
The 8000 series uses DViT technology to identify when you switch between your finger, a pen or an eraser.
You can write notes over any lesson and save them as a SMART Notebook file.
The 8000 series is equipped with two pens that magnetically attach to the bezel. Its control buttons enable you to select the color of ink, right-click and launch the On-Screen Keyboard and help functions.
The 8000 series features a hardened glass display.
