A New Shocking Experience for Entertainment
The Shuttle SH87R6 is official debut with new R6 chassis design. Equipped with the latest Intel® H87 express chipset supports the Intel® Haswell processor, the latest fourth-generation Core™3/i5/i7 processor, integrating new Intel® HD Graphics core (Note), support 7.1 channel audio output, designed for high-definition video entertainment. For expansion, it features with one PCI-Ex16 and one PCI-Ex1 slot, Mini-PCIe slot, multiple USB 2.0 and USB 3.0 ports, SATA 6Gbps interface and supports expansion slots of two 3.5"drives and one 5.25" drive. The SH87R6 is equipped with Shuttle exclusive I.C.E.2 heat pipe technology and a 300W with 80 Plus Bronze certified power supply that features high stability for long-term operation and energy saving. *Processor integrated graphic core performance with different models, and its performance may also different.
- Shuttle XPC SH87R6 - no CPU - Monitor : none.
- Form Factor
- Mini PC
- Processor
- Intel no CPU
- RAM
- 0 MB (installed) / 32 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA ( SATA 6Gb/s )
- Hard Drive
- No HDD
- Monitor
- None.
- Audio Output
- Integrated
- Networking
- Gigabit LAN
- Power
- AC 120/230 V
- OS Provided
- No operating system
- Environmental Standards
- ENERGY STAR Qualified
- Product Form Factor
- Mini PC
Processor / Chipset
- CPU
- Intel no CPU
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
RAM
- Installed Size
- 0 MB / 32 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1
Card Reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- DVI, HDMI
Audio Output
- Integrated
- High Definition Audio
- Integrated
- Ethernet Controller
- Realtek RTL8111E
- Wireless LAN Supported
- Data Link Protocol
- Wake on LAN (WoL)
- IEEE 802.3u
- Security lock slot (cable lock sold separately), active Power Factor Correction (PFC)
- C-Tick, RoHS, Energy-using Products (EuP) Lot 6
- Nominal Voltage
- AC 120/230 V
- 80 PLUS Certification
- 80 PLUS Bronze
Operating System / Software
- OS Provided
- 35 °C
- 10 - 90% (non-condensing)
