Sharp PN-E471R - 47" LCD flat panel display - 1080p (FullHD)
Quicklinx: 834CWS00 Mfr#: PNE471R
  • 1080p
The 47" class (46-15/16" diagonal) PN-E471R LCD monitor offers exceptionally high image quality and reliability for use in commercial display and digital signage applications. 24/7 certified, the thin bezel PN-E471R offers full 1920 x 1080 (1080p) resolution from analog RGB, digital RGB and HDTV video sources along with compatibility for use in both portrait and landscape modes. Fanless architecture helps ensure ultra-quiet reliable operation, and optional input/output expansion board and signage controller provide maximum flexibility. Also available is the PN-E471RP, which features an integrated protective overlay for use in high traffic areas.
Sharp PN-E471R 47" LCD flat panel display - Full HD
Diagonal Class
47"
Country Kits
Europe
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
Max Number of Screens
25
Video Interface
HDMI
PC Interface
VGA (HD-15)
HDCP Compatible
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote control
Voltage
AC 120/230 V
260 watt
108 cm x 11.1 cm x 62.8 cm
25.5 kg
Environmental Standards
ENERGY STAR Qualified
260 watt
Diagonal Class
47"
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Landscape mode
Dimensions
Without stand
108 cm
11.1 cm
62.8 cm
25.5 kg
Country Kits
Europe
Display
Resolution
1920 x 1080
Display Format
1080p
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Backlight Life
50,000 hour(s)
Certified for 24/7 Continuous Operation
Video Wall
25
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 400 x 200 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x main channel speaker - 10 watt
Connector Type
Audio line-in , HDMI input , Audio line-out , Serial
EMC Class A
Sustainability Information
ENERGY STAR Certified
Power supply - internal
Input Voltage
AC 120/230 V
Power Consumption Stand by / Sleep
0.7 watt
