From up close or far away, preserve the moment exactly how you want to remember it. Capture a spectacular mural that takes up the entire side of a building or a field of colorful wildflowers that seems to stretch for miles-with the 24 mm wide-angle lens. When you can't get physically closer to your subject, such as a windsurfer sailing across the sea, the 12x optical zoom lets you capture every sharp detail.
Tiny sensors tend to lead to noisy pictures. The WB35F, however, comes equipped with a 16-megapixel CCD sensor that's larger-1/2.3", to be exact-than those found in most compact digital cameras. The results are vivid yet natural images, whether you're shooting in a dimly lit room or outside on a sunny day.
12x optical zoom, 24 mm wide angle
From up close or far away, preserve the moment exactly how you want to remember it. Capture a spectacular mural that takes up the entire side of a building or a field of colorful wildflowers that seems to stretch for miles-with the 24 mm wide-angle lens. When you can't get physically closer to your subject, such as a windsurfer sailing across the sea, the 12x optical zoom lets you capture every sharp detail. -
Tag&Go (photo beam, AutoShare, remote viewfinder, mobile link)
Tag&Go (NFC/Wi-Fi) features like photo beam, AutoShare, remote viewfinder and mobile link let you share images to compatible smartphones right next to you or on the other side of the world. Photo Beam easily sends any photo that you're viewing to a smartphone instantly. AutoShare saves photos to your smartphone as you shoot and with Remote Viewfinder, you can control your camera with your smartphone. Effortlessly post photos to social networks and store them on the cloud. -
Smart mode
Like the perfect trails of light at night on a busy intersection full of red taillights. Or instantly capture a high-speed scene with Action Freeze. A quick tap of smart mode and you're set with various special modes. Just choose the one you want and shoot perfection. -
16M CCD sensor
Tiny sensors tend to lead to noisy pictures. The WB35F, however, comes equipped with a 16-megapixel CCD sensor that's larger-1/2.3", to be exact-than those found in most compact digital cameras. The results are vivid yet natural images, whether you're shooting in a dimly lit room or outside on a sunny day. -
Photo/video filter
Just because you can capture reality as you see it doesn't mean you have to. Samsung's Smart Filter gives you creative license to produce artistic images. Reignite childlike wonder with the Miniature filter, which can make a cityscape look like a play set. Other effects include Vignetting, Classic, Retro, Cross Filter, and Fish Eye. -
Live panorama
With live panorama, you can capture a seemingly endless procession of gondolas gliding past a magnificent Venetian palace with an astounding 180ยบ panoramic image. And you can preview the image on the LCD before you even snap it. Just hold the shutter button, sweep across the scene and see what you're going to get before you get it. -
Smart auto
Turn fleeting moments into memories with professional-style results. The Samsung Smart Camera's smart auto automatically analyzes the shooting environment and then chooses the appropriate scene mode for the best possible results. Smart auto analyzes key elements in the composition and automatically adjusts its various modes to capture the best shot.
- Samsung SMART Camera WB35F - digital camera
- Product Type
- Digital camera - compact
- Memory Card Slot
- microSD card
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 16.2 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- 12 x zoom lens - 4.3 - 51.6 mm - f/3.1-6.3
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 80 cm
- Digital Zoom
- 2 x
- Image Stabiliser
- Optical
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- 1 x Samsung BP-70A Li-ion rechargeable battery ( included )
- Interfaces Provided
- Composite video/audio, USB 2.0
- Black
- 10.09 cm x 2.75 cm x 6.12 cm
- 145 g
- Product Type
- Enclosure Colour
- Black
- Sensor Resolution
- 16.2 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 16,600,000 pixels
- Effective Sensor Resolution
- 16,200,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 3200
- IEEE 802.11b/g/n, NFC (Near Field Communication)
- Optical Zoom
- 12 x
- Digital Zoom
- 2 x
- Image Stabiliser
- Optical
- Face Detection
- Print Standard
- Exif Print support
- Auto Focus
- TTL contrast detection
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Face Detection AF/AE
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- 1280 x 720
Communications
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Special Effects
- Fisheye, miniature, Classic, Retro, cross filter, Vignetting
- Retouch
- Face retouch
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, tungsten light, daylight, fluorescent light (cool white), fluorescent light (warm white)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 8 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- Exposure Range
- EV 2-17 - wide lens ( ISO auto ) , EV 4-19 - tele lens ( ISO auto )
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 288mm
- Focus Adjustment
- Automatic, manual
- 80 cm
- Macro Focus Range
- 5cm
- Zoom Adjustment
- Motorised drive
- Built-in lens shield
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- AF illuminator
- Effective Flash Range
- 0.2 m - 4 m : ISO auto ( wide lens ) , 0.5 m - 1.6 m : ISO auto ( tele lens )
Additional Features
- Self Timer Delay
- 10 sec, 2sec
- Additional Features
- Audio recording, built-in speaker, date/time stamp, digital image rotation, cropping an image, resizing an image, saturation control, 720p HD movie recording, in-camera red-eye fix, USB charging, Auto Contrast Balance (ACB), Smart AUTO, Live Panorama function, Tag & Go (NFC/Wi-Fi)
Display
- 3" LCD display
- Resolution
- 230,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Contrast control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- 1 x USB 2.0 , 1 x composite video/audio output
- Memory Card Slot
- microSD card
Software
- Software
- Drivers & Utilities
- Included Accessories
- Carrying strap, AC power adaptor, USB cable
- Battery Type
- Samsung BP-70A
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Included Memory Card
- 16 GB microSDHC
- Memory Card Max Supported Size
- 64 GB
- Image Storage
- JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3648 x 2736 , JPEG 2592 x 1944 , JPEG 1984 x 1488 , JPEG 1920 x 1080 , JPEG 1024 x 768
- Video Capture
- H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps , H.264 - 320 x 240 - 30 fps
- 10.09 cm
- 2.75 cm
- 6.12 cm
- 145 g
- 0 °C
- 40 °C
- 5 - 85%
