Create detailed DSLR quality pictures and cinematic Full HD movies with ease, even in difficult low light situations, using the 24.1-megapixel EOS 2000D. Share instantly and shoot remotely with Wi-Fi and NFC.
Superb photos, cinematic movies
Step up to a 24.1-megapixel sensor that has up to 19x more surface area than many smartphones to capture stories with beautiful background blur, even in tricky light. -
Effortless creativity
Enjoy guided Live View shooting with Creative Auto mode and add unique finishes with Creative Filters. Just point and shoot for great results with Scene Intelligent Auto. -
Bring everyday moments to life with EOS 2000D
Turn spontaneous moments into creative films in Full HD, or use Video Snapshot to simply capture highlights of your day. -
Shoot with confidence
Capture the moment just as you remember with precise Auto Focus, 3.0 fps and DIGIC 4+. Enjoy easy framing with the optical viewfinder and see results on a 7.5 cm LCD screen. -
Easy sharing, remote shooting
Instantly transfer your stories to your smart device, for easy sharing on social media or irista cloud backup, and shoot remotely with Wi-Fi and NFC.
- Canon EOS 2000D - digital camera - body only
- Product Type
- Digital camera - 1080p - SLR with Live View mode, movie recording
- Lens Included
- Body only
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4+
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 24.1 Megapixel
- Max Video Resolution
- 1920 x 1080
- Image Stabiliser
- Optical
- Camera Flash
- Pop-up flash
- Viewfinder
- Optical - fixed eye-level pentamirror
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E10 Li-ion rechargeable battery (included)
- Interface
- HDMI, USB 2.0
- 12.9 cm x 7.76 cm x 10.13 cm
- 475 g
- Product Type
- Lens Included
- Body only
- Sensor Resolution
- 24.1 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 24,700,000 pixels
- Effective Sensor Resolution
- 24,100,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- Frame Rate (Max Resolution)
- 30 fps
- ISO (Max)
- 12800
- Image Processor
- DIGIC 4+
- Image Stabiliser
- Optical
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast and phase detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- FlexiZone, Predictive AI Servo AF
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Audio Signal Format
- PCM
- Auto Focus Features
- Predictive Focus Control
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 12800, ISO 100-6400, ISO auto (100-6400)
- Exposure Metering
- Evaluative, partial (10%), centre-weighted
- Exposure Metering Zones
- 63
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, close-up, night portrait, food, sports mode
- Bracketing Modes
- White balance bracketing
- Special Effects
- Neutral, Custom Effect, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, Toy camera, Grainy B&W, Standard
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, tungsten light, Flash, daylight, shade, 2500K - 10000K (100K steps), fluorescent light (white)
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±5 EV range, in 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/2 or 1/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/200sec
- Exposure Range
- EV 1-20 (ISO 100)
Lens System
- Lens Mounting Type
- Canon EF/EF-S
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 9.2
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 3 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- RGB primary colour filter, auto power save, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, highlight tone priority, highlight point display, Dust Delete Data system, built-in help guide, peripheral illumination correction, Scene Intelligent Auto technology, noise reduction over long exposures, high ISO speed noise reduction
Tripod Mount
- Connection Point
- 1/4" socket
Viewfinder
- Viewfinder Type
- Optical Viewfinder Field Coverage
- 95%
- Optical Viewfinder Magnification
- 0.8x
- Optical Viewfinder Dioptric Correction Range
- -2.5 to +0.5
Display
- 3" LCD display
- Display Format
- 920,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , HDMI output (19 pin mini HDMI Type C)
- Included Accessories
- Battery charger, body cap, neck strap, USB cable, eyecup
- Body Material
- Fibreglass-reinforced polycarbonate resin
- Battery Type
- Canon LP-E10 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 500 shots (at 23 °C (AE 50%, FE 50%)) , Photo shooting - 410 shots (at 0 °C (AE 50%, FE 50%))
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- RAW 6000 x 4000 , JPEG 6000 x 4000 , JPEG 3984 x 2656 , JPEG 2976 x 1984 , JPEG 1920 x 1280 , JPEG 720 x 480 , JPEG 5328 x 4000 , JPEG 3552 x 2664 , JPEG 2656 x 1992 , JPEG 1696 x 1280 , JPEG 640 x 480 , JPEG 6000 x 3368 , JPEG 3984 x 2240 , JPEG 2976 x 1680 , JPEG 1920 x 1080 , JPEG 720 x 408 , JPEG 4000 x 4000 , JPEG 2656 x 2656 , JPEG 1984 x 1984 , JPEG 1280 x 1280 , JPEG 480 x 480
- Video Capture
- MOV - 1920 x 1080 p - 30 fps , MOV - 1920 x 1080 p - 25 fps , MOV - 1920 x 1080 p - 24 fps , MOV - 1280 x 720 p - 60 fps , MOV - 1280 x 720 p - 50 fps , MOV - 640 x 480 p - 30 fps , MOV - 640 x 480 p - 25 fps
- 12.9 cm
- 7.76 cm
- 10.13 cm
- 475 g
- Weight Details
- Camera with battery and memory card: 475 g
- 0 °C
- 40 °C
- 0 - 85%
Canon TC 80N3 - camera remote control | In Stock | £126.83 |
Canon Speedlite 430EX III - RT Flashgun Black | In Stock | £227.08 |
