The SMT-1934 features a 16:9 aspect ratio wide screen and supports up to 1280 x 1024 resolution, delivering superior image quality DNIe (Digital Natural Image engine). Designed specifically for use in professional security systems it possesses a dynamic contrast ratio of 1000:1, with a 5 ms response time. The SMT-1934 is intended to provide security system operators with a high performance durable display solution.
- Samsung SMT-1934 LCD display
- LCD display
- Recommended Use
- Surveillance system
- Supported Image Aspect Ratio
- 4:3
- Colour Support
- Display Size
- 19"
- Resolution
- 1280 x 1024 - 600 TVL
- Video Format
- NTSC, PAL
- Supported Video Signals
- Composite video, VGA, HDMI
- Built-in Speakers
- 2 speakers
- 3D comb filter, LED backlight
- Kit Content
- 1 x remote control
- Black
- Voltage Required
- AC 120/230 V
- Power Consumption
- 35 Watt
- LCD display
- 41.2 cm
- 21.74 cm
- 40.65 cm
- 5 kg
CCTV
- Equipment Category
- CCTV monitors
- Composite video, VGA, HDMI; NTSC, PAL
- Horizontal Resolution (TV Lines)
- 600
- Audio Support
Studio & Field Monitors
- Recommended Use
- 4:3
- Colour Support
- Display Size
- 19"
- Native Resolution
- 1280 x 1024
- Built-in Speakers
- 2 speakers
- Voltage Required
- AC 120/230 V
- Frequency
- 50/60 Hz
- Power Consumption
- 35 Watt
- Black
Kit Content
- Kit Content
- (1) x remote control
Terminals
- Terminals
- (2) x composite video input - BNC - with loop through , (1) x HDMI input - 19 pin HDMI Type A , (1) x VGA input - 15 pin HD D-Sub (HD-15) , (2) x audio line-in - RCA x 2
- 0 °C
- 40 °C
